I happened to have my camera while installing my A-TRAC switch today and figured I'd shoot a short "how-to' video while I was at it. This is literally one of the easiest items you can add to your FJ if you don't already have one.
This is easier to install than the '08 side visors!
Two quick things to remember:
1. Adding the A-TRAC switch is only for 4WD FJs with the locking rear differential.
2. A-TRAC will work with the locker up to 4 mph from the factory. No further modifications are required
__________________ Bilstein 5100 adjustables, Toytec rears with ProComps, Rasta front and center skids, Trail-Gear t-case skid, All-Pro high tuck tailpipe, Total Chaos Lower Link Skids, Harbor Freight hitch mounted disposable backup light, modified TT rear skid, SCUBA mod...
Which would you rather do, slide down a 50 foot razor blade or suck all the snot out of a dog's nose until their head caves in?
I still can't believe that it took a minute and a half, actually less if I wasn't narrating.
Thanks for that. I agree, that took longer than the Tundra handle install!
05/06 built '07 6MT accessorized with the following:
LT285/70/r17 Nitto Terra Grapplers on stock rims, Extreme Truck Toys 3" spacer lift, Demello front single hoop bumper + skid plate, K&N CAI Intake as reviewed by me here on FJFCs, Trail Gear sliders, Cobra 76 XTR CB + 3' Wilson Silver Load antenna mounted up front, A-TRAC hack and custom trail rash from all over Texas.
BLK CHERRY
ATM, 4WHD
REAR DIFF LOCK
A-TRAC
OEM ROCK RAILS
TRAILGEAR TRANSFER SKID
TOYOTA BLACK STEEL WHEELS
MICKEY THOMPSON BAJA MTZ
REAR DIFF SCUBA MOD
R/C 3INCH LIFT
UNIDEN C.B
BANDI MOUNT.
SIRIUS RADIO
GARMIN NUVI 255w
BULL BAR WITH HELLA 500
HIGH LIFT WITH MAN-A-FRE SPARE TIRE MOUNT
T.L.C.A. #19204 http://www.fjnortheasters.org
