Old 02-29-2008, 02:05 PM   #101
AmityFJ's Avatar
Member Number: 6978
Re: Installed the GOBI Stealth yesterday
Chrs previously said: View Post
Thanks for the tips.
How difficult was it to get to lift the rack up on the roof?
You can do most of the install by yourself, but you will definately need at least one other person to lift into place.
Regarding the wiring, If you are not installing lights, just leave it in the plastic and zip tie it to the rack tightly making sure water would not get into the wrapping.
Also they gave me metal brackets to attach to where the lights would go. Really helped with the wind noise. I attached reflectors up there so they wouldn't look like black false teeth. Now I barely hear any wind at all. I will probably get lights soon, but those brackets did the trick for the noise. I would make sure they include it with when they send your rack.
TLCA# 17487
AmityFJ is offline
Old 02-29-2008, 08:35 PM   #102
Chrs's Avatar
Member Number: 5074
Send a message via AIM to Chrs Send a message via MSN to Chrs Send a message via Yahoo to Chrs
It sounds easy, but I'm just afraid to screw things up.
As noobish as this sounds, does anyone have pics of them lifting the rack on the roof? My old man wants to do it using a hoist/string...
Chrs is online now
Old 02-29-2008, 08:47 PM   #103
5280FJ's Avatar
Member Number: 7663
I'm a fat, old, stupid person and did it on my own. Put it on my PullPal matt (cover) and pressed it up from behind. Two people should easily be able to do it. Get more people if you are worried. Once it's on you will not regret it.
5280FJ is offline
Old 03-04-2008, 11:32 PM   #104
Chrs's Avatar
Member Number: 5074
I haven't gotten a chance to install yet due to work and family emergencies.
I plan to put a matt/blanket on top. Then with the help of someone else, lift the rack up and push it from the side. Does this sound reasonable? I just don't want to scratch or dent the roof.
Chrs is online now
Old 03-08-2008, 06:40 PM   #105
Chrs's Avatar
Member Number: 5074
AmityFJ previously said: View Post
Are these the brackets you were talking about:
Chrs is online now
Old 04-24-2008, 08:21 PM   #106
Member Number: 18661
Any insight into loading surfboards, or 14' paddleboards on the Gobi, would yakima or thule install on the Gobi, thanks, great thread.
sc409 is offline
Old 04-24-2008, 08:35 PM   #107
ippon20's Avatar
Member Number: 4041
sc409 previously said: View Post
You'll need Yakima Claws to attach your crossbars to the Gobi. I did that with my ARB rack and they work great. It's an easy thing to strap my 9'1'' on top.
Voodoo 4x4, convenience pkg., black steelies, locking diff, trail gear sliders, ARB Roof Rack, Toytec Ultimate Lift and Light Racing UCA's
ippon20 is offline
Old 04-30-2008, 09:42 PM   #108
Member Number: 16732
ippon20 previously said: View Post
I was under the impression that Yakima attachments will fit directly on the two Gobi crossbars, so that you wouldn't need Yakima mounts or Yakima crossbars. Do I have that wrong?
SLOTRKR is offline
Old 05-06-2008, 10:25 PM   #109
ippon20's Avatar
Member Number: 4041
SLOTRKR previously said: View Post
yes and no...the attachments fit to the Gobi as it's the same tubing. But for my application (surfboards), I needed the crossbars above the rack because the rails would get in the way. Other than that, yes when I was checking out racks...GOBI did verify that their tubing was a fit for Yak.
ippon20 is offline
