Old 05-21-2006, 04:18 PM   #21
granger's Avatar
Member Number: 50
Re: Installed the GOBI Stealth yesterday
gsgmac previously said:
Granger, I like you rack! I know that sounds kinda creepy, but oh well. Nice job man! Now load that somana beyotch up with a whole bunch of shiznit!
HA!!!!! thanks
TLCA#15587
granger is offline
Old 05-21-2006, 04:23 PM   #22
Everything In Moderation
Landrover's Avatar
Member Number: 772
granger previously said:
As of right now I have no plans to lift my FJC. On paper I can live with the sag the ARB is going to cause, if it or my handling suffers I will revisit a suspension upgrade. In that case I have been looking at the OME, Danahoe and All Pro lifts. I just put new tires on my truck and I know if I lift it I will want to go bigger.
Little off topic, but are you talking front end sag with the ARB and winch or just the bumper? Was just wondering if you could get away with stock front end with bumper and winch.
Landrover is offline
Old 05-21-2006, 04:34 PM   #23
granger's Avatar
Member Number: 50
I think you can, others don't.
Kansas Law Dog and I came up with some very unscientific numbers:
Starting on the 3rd post down
ARB First Shipment
Just conducted a rather unscientific test.
Adding 240lbs to the bumper of the FJ Cruiser dropped the front end 7/8".
Weight of the ARB (Approx): 110lbs to 120lbs
Weight of a Warn XD9000: 78lbs
Total Weight: 188lbs to 198lbs
Which means that the front drops 0.0036458 inches for every pound added.
So: 240 * 0.0036458 = .875 = 7/8ths
With the winch and bumper: 188 * 0.0036458 = 0.6854104" (about 5/8")
With the winch and bumper: 198 * 0.0036458 = 0.7218684" (about 3/4")
Bumper Alone: 110 * .0036458 = 0.401038" (under a 1/2")
Bumper Alone: 120 * .0036458 = 0.437496" (under a 1/2")
TLCA#15587
granger is offline
Old 05-21-2006, 06:01 PM   #24
Landrover's Avatar
Member Number: 772
I'll buy that equation. Although if the FJ comes stock with progressive rate springs, meaning they get firmer as compression increases, you would't even have that much drop as the combo is quite a bit lighter than the 240 lbs. Will check out the other thread for more info and updates.
Now, back to our regularly scheduled program already in progress......
EXTREME TV's: GOBI RACK - STEALTH EDITION
Old 05-21-2006, 06:45 PM   #25
CO-Jeff's Avatar
Member Number: 1863
Send a message via AIM to CO-Jeff
I get my Gobi Ranger Tuesday morning driving over for the install, hope the wiring is a breeze.
Will post pics of the install and wiring.
CO-Jeff is offline
Old 05-21-2006, 07:31 PM   #26
L8Apex's Avatar
Member Number: 2080
Granger, your FJ looks awesome with the Gobi rack! My FJ has the factory rack, but your pics make me reconsider.
I have one question: If you were to load a long item in the rack (like a ladder or a long 2x4), with one end of sitting in the front of the basket, will the other end rest nicely on the rear rail of the rack without "see-sawing" over the curve in the middle?
Keep us updated when you install lights!
The Tank (aka "RED PILL") : 2007 FJ Cruiser, 4x4AT, black cherry
- Expedition One bullbar bumper
- Expedition One rock sliders
- BudBuilt skids (front, mid, TC, crossmember)
- Bilstein 5100 front struts, set at 1.75" lift
- GoodYear Wrangler Silent Armor tires 275/70/R17
The Fighter Jet: 2001 MR2 Spyder, silver
- 2ZZ motor/6spd swap
- TRD Sportivo suspension
- 3.0 Racing chassis bracing
- JDM Toyota hardtop, soft-top delete
L8Apex is offline
Old 05-21-2006, 08:20 PM   #27
granger's Avatar
Member Number: 50
I think it would see-saw but the cross bars are level so as long as you tie down to them it should be stable. Not sure how much you would want to overhang past the cross bars though.
There is one cross bar just past the opening behind the front lights and another about half way back. They are level with each other so rack systems like Thule and Yak will work, as would tying down ladders, boards etc...
TLCA#15587
granger is offline
Old 05-21-2006, 08:32 PM   #28
JimmyHoops's Avatar
Member Number: 1812
Jeff,
After you get the Gobi installed, I'd like to meet up to take a closer look. Also, did you get the ladder?
Missin' my FJ 40 But lovin' my FJ Cruiser
Rides:
'03 Audi A6 2.7 Bi-Turbo, Silver
'07 FJ Cruiser, Voodoo Blue, M/T6 Option#2 w/Rack
JimmyHoops is offline
Old 05-21-2006, 08:43 PM   #29
FJ Boba's Avatar
Member Number: 1856
How much is the ladder only? since my blue FJ already came with factory roof rack.
FJ Boba is offline
Old 05-21-2006, 08:44 PM   #30
granger's Avatar
Member Number: 50
I believe it is $300 plus shipping.
TLCA#15587
granger is offline
