Old 01-09-2008, 02:00 AM   #11
Super Moderator
Fjamming's Avatar
Member Number: 6623
Re: Does size matter.... in a power tank?
I'm talking about just a portable compressor like the qmaxx.
Sandoo Blue FJ
SoCal Events Calendar
Fjamming is offline
Old 01-09-2008, 02:39 AM   #12
cruiserlarry's Avatar
Member Number: 2011
So I am going to be ordering a power tank here this week and was wondering what size you all would recommend. There chart has a PT10 filling ~20 (5 rigs) 295/75/16 tires 20psi, and a PT15 can fill ~30 tires(7.5 rigs) a PT20 can fill ~40 tires(10 rigs). What do you all think?
I am leaning to a 15 should I go even bigger or maybe smaller.
The 10 pounder is the easiest to fit in the vehicle - it will stand up or lay down on the driver's side rear shelf. Also, if you need to carry it around, it's (obviously, I guess) lighter. I think you are better off with 2 10 lb tanks than 1 20 lb tank...
W6LPB / WPOK492
TLCA #9632
cruiserlarry is offline
Old 01-09-2008, 10:58 AM   #13
jeshua's Avatar
Member Number: 6888
cruiserlarry previously said: View Post
Thanks Larry. So the tanks can be laid down or do you recommend standing them up.
The coupon is only good for ONE power tank system other wise I would think more about going with the 2 10's
Mike Ambs
www.corva.org
- Thomas Paine
Aequitas - Veritas
jeshua is offline
Old 01-09-2008, 10:59 AM   #14
jeshua's Avatar
Member Number: 6888
I really don't like those, all the ones I have seen take for ever to fill a tire.
Mike Ambs
www.corva.org
- Thomas Paine
Aequitas - Veritas
jeshua is offline
Old 01-09-2008, 12:16 PM   #15
Super Moderator
Fjamming's Avatar
Member Number: 6623
4.5 min to fill a tire from 20 psi to 35 (stock). It's not CO2, but it's acceptable.
The tanks can be lay on it's side, but when you use it, it should be standing.
Sandoo Blue FJ
Fjamming is offline
Old 01-09-2008, 12:35 PM   #16
Member Number: 7679
I have the 15lb version and have mounted it upright on the shelf on the left side of the cargo area. However, I cannot mount the handle to the Powertank because it hits the ceiling. Not a problem for myself as I can airup with the tank mounted, but if I want to take the tank out, having no handle makes it awkward.
Hardluck is offline
Old 01-09-2008, 12:39 PM   #17
jeshua's Avatar
Member Number: 6888
Hardluck previously said: View Post
Thanks. Do you know the height with out the handle?
Mike Ambs
www.corva.org
- Thomas Paine
Aequitas - Veritas
jeshua is offline
Old 01-09-2008, 03:25 PM   #18
Member Number: 7679
I'll measure tonight when I get home.
Hardluck is offline
Old 01-09-2008, 03:35 PM   #19
Banned
Member Number: 10257
Well since my first answer sucked at such an insane level...I took some measurements for ya'
Tank mounted to back corner on floor
Height with handle...29 1/2"
Height to valve 27"
Other side shelf to roof 22"
does-size-matter-power-tank-100_5937.jpg  does-size-matter-power-tank-100_5938.jpg  does-size-matter-power-tank-100_5939.jpg  does-size-matter-power-tank-100_5940.jpg
homedad is offline
Old 01-09-2008, 03:43 PM   #20
jeshua's Avatar
Member Number: 6888
Thanks homedad for the measurements to the top of the valve. Rep to you!
I think I will ether go with a 10 or 20 depending on what fits, I see no reason to do the 15 when the 20 is the same height. I built some drawers in the back so that eats up some height. I will have to take a close look at my rear and see what I can do.
my box
Mike Ambs
www.corva.org
- Thomas Paine
Aequitas - Veritas
jeshua is offline
