Old 01-09-2008, 03:58 PM   #21
Banned
Member Number: 10257
Re: Does size matter.... in a power tank?
Thanks homedad for the measurements to the top of the valve. Rep to you!
I think I will ether go with a 10 or 20 depending on what fits, I see no reason to do the 15 when the 20 is the same height. I built some drawers in the back so that eats up some height. I will have to take a close look at my rear and see what I can do.
my box
After looking at your box pic...I took a guess and called it 3" from the top of the box to the top of the shelf....assuming that is correct you have 30" to the roof liner....1/2" to spare....good to go..if you bolt it right to the top left corner of the box in the rear by the seat back...
Good luck...and I hope I helped...even though you can't rep me
Kurt
homedad is offline
Old 01-09-2008, 04:02 PM   #22
jeshua's Avatar
Member Number: 6888
You helped for sure!! I will always have rep in my mind they can't take that away!!!!
I will let you now what I come up with it.
Mike Ambs
www.corva.org
- Thomas Paine
Aequitas - Veritas
jeshua is offline
Old 01-09-2008, 04:19 PM   #23
Member Number: 7679
Sorry Jeshua. I just remembered I have the PT-10, not PT-15. That's what I get for responding from work w/o thinking through.
Hardluck is offline
Old 01-25-2008, 03:29 PM   #24
jeshua's Avatar
Member Number: 6888
Thanks again every one that helped me out. I just ordered a PT10 package B in Candy Blue. Should get it mid next week I would think.
Mike Ambs
www.corva.org
- Thomas Paine
Aequitas - Veritas
jeshua is offline
Old 01-25-2008, 03:45 PM   #25
Super Moderator
Fjamming's Avatar
Member Number: 6623
Got your fill location lined up?
Sandoo Blue FJ
SoCal Events Calendar
Fjamming is offline
Old 01-25-2008, 04:02 PM   #26
jeshua's Avatar
Member Number: 6888
Nope I still haven't called around. I need to though so I have it ready for Mojave run.
Mike Ambs
www.corva.org
- Thomas Paine
Aequitas - Veritas
jeshua is offline
Old 01-25-2008, 11:06 PM   #27
cowboy4x4's Avatar
Member Number: 12116
Hey Josh I remember some time ago someone hear compiled a list from everybody on fill up locations try a search I'll try as well.
Edit I found it ...it is in the socal region section...hope that helps
Edit fjamming did it and I see he is hear so I guess the list wont help..oh well
If I want to be found I'll push the SPOT otherwise I'm invisible......KI6OBK...OverlandXT....Tread Lightly Trainer
cowboy4x4 is offline
Old 01-26-2008, 01:58 AM   #28
sdlsatcom's Avatar
Member Number: 10814
i went with the 10 pounder so i could mount it in that goofy useless spot
"the choice of the people is freedom"
sdlsatcom is offline
Old 01-26-2008, 03:37 AM   #29
jeshua's Avatar
Member Number: 6888
cowboy4x4 previously said: View Post
That list should be called the OC LA CO2 fill up locations. I need to check with the local shops for a fill up station. maybe temecula area or Moval perris area.
sdlsatcom previously said: View Post
I plan to mount mine standing up on the passenger side rear fender.
Mike Ambs
www.corva.org
- Thomas Paine
Aequitas - Veritas
jeshua is offline
Old 01-26-2008, 02:51 PM   #30
Super Moderator
Fjamming's Avatar
Member Number: 6623
Josh, make IE proud. Be the one to provide a few locations. You are our SoCal IE rep!
Sandoo Blue FJ
Fjamming is offline
