Old 03-03-2008, 09:39 AM   #1 (permalink)
Member Number: 13466
Question when in 4 wheel high
Hi guys,
Here's a stupid question. I was in 4 high yesterday on dry pavement just to exercise the components. When I started from a stop and moved forward slowly (into my garage, into a parking space, etc), it took a lot more force on the gas pedal to get moving. I don't remember my '03 4runner doing this, is it normal?
Ya, I definitely need to get the FJ out in 4 wheel drive more.
Thanks for any comments.
fjdebt is offline
Old 03-03-2008, 10:06 AM   #2 (permalink)
LV_UXO's Avatar
Member Number: 17146
Re: Question when in 4 wheel high
Sounds like you might have had some driveline binding. That often occurs when on 4x4 mode on dry pavement. Even without lockers and such, your diffs and tranfer case can tighten up pretty quick without having some amount of slippage where the rubber meets the road. Driving absolutely straight still binds the works because rarely are your rolling radii exactly the same on all tires. Whenever you feel the need to "exercise" your front end components, it would be a good idea to find a dirt lot or gravel road to drive on. It would be a lot less stressful on your running gear.
Mike
I do not like this word "bomb." It is not a bomb. It is a device that is exploding. Jacques le Blanc
LV_UXO is offline
Old 03-03-2008, 11:34 AM   #3 (permalink)
Thanks Mike. All the info is very much appreciated. I'm still learning a lot about this truck and enjoying every minute of it. I took it to work this morning and everything seemed normal. I was probably turning more than I thought before. I'll take it to the hills next time.
Thanks again.
Paul
fjdebt is offline
Old 03-03-2008, 06:03 PM   #4 (permalink)
The Laughing Moderator
LandCruiserSteve's Avatar
Member Number: 8627
LV_UXO previously said: View Post
Well said and explained.
Steve
The '07 Kiroi Hako
'59 FJ25
'78 FJ40
TLCA #6727
UFWDA
LandCruiserSteve is offline
Old 03-03-2008, 06:31 PM   #5 (permalink)
layonnn's Avatar
Member Number: 10006
My first vehicle did this, a 20 year old CJ-7. I had just thought that it was because it was old that it did had the exact same issue. No turning in 4hi or lo on pavement. Not good for drive train.
Layton
2007 Supercharged Voodoo 5AT 4x4
"God forgives...rocks don't"
layonnn is offline
Old 03-03-2008, 08:18 PM   #6 (permalink)
Archy Chris's Avatar
Member Number: 7128
X3!
'07 Voodoo Blue/6MT/Upgrade #1 Package/Roof Rack/Towing Package/ALL-PRO Mods: Front Bumper w/Prerunner Light Bar, Rock Guards, Full Skid Plates, High Clearance Exhaust, Ultimate Lower Skids, Shock Skids/aFe Pro-Guard 7 CAI/KC Daylighters/BFG AT/KO's 285x70x17 Tires/Magnaflow Exhaust/Man-A-Fre Extended Brake Lines/Power Tank/Manik Taillight Guards & Roof Rack Light Bar/SWAY-A-WAY Coil-Over Suspension/Light Racing Adjustable UCA/Safari Snorkel, SCUBA Mods + a butt load more mods..
Archy Chris is offline
Old 03-03-2008, 08:21 PM   #7 (permalink)
chichid65's Avatar
Member Number: 15447
Archy Chris previously said: View Post
X3!
I agree 100%.
"A Year Of Change"
2008 FJ-VooDoo blue/4x4/AT/GPS/K&N Air Filter/Revos/Up Pkg.2/VIP RS3200 Plus Security System/OEM Roof Rack/OEM Rock Rails/Tow Package/All Weather Floor Mats & Rear cargo Mat//Recovery strap.
chichid65 is offline
