Old 06-01-2006, 10:52 AM   #21
Member Number: 639
Re: ARB Bumper + Warn M8000 Installation - LOTS of pictures
SnoutDog previously said:
Looks great and the detailed post is super!! Question: Will you be available to pull a Voodoo blue out of the mud?
Sure thing! You just need to make sure that either Andy or I go wheeling with you and you're covered.
sbechtold is offline
Old 06-01-2006, 11:48 AM   #22
alaskanrover
Guest
Member Number:
Posts: n/a
bandi previously said:
Alaskan...
Hmmm... I see all the links above and in your post too... STRANGE !!!
Thanks Bandi, found the problem...network gods are limiting my link-age abilities....
I must go now and pray they allow me to get to the links even though everyone else can see them and I can't......(wimper)
Old 06-02-2006, 12:51 AM   #23
Member Number: 639
After driving the FJ around a little I have found that the front end has settled and is lower then I originally thought. The front end is now about 1" lower then it was before I installed the ARB bumper and winch. Not a big deal to me, but definitely noticeable when you look at it from the side or drive it.
I have an OME lift kit on order and will be installing a medium sprung lift once they make it here from AU. This should level the FJ out.
Old 06-02-2006, 02:29 AM   #24
cruiserlarry's Avatar
Member Number: 2011
Lightbulb Re: ARB Bumper + Warn M8000 Installation - LOTS of pictures
If you'd "spring" (pun intended) for the Donahoe coilover system, you would be able to adjust the height to the exact height required to level vehicle, instead of settling for the fixed height of the front OME coil / strut assembly...just a suggestion...
W6LPB / WPOK492
TLCA #9632
cruiserlarry is offline
Old 06-02-2006, 09:14 AM   #25
Member Number: 836
You think the medium is the way to go? I will have the same set up and want a level truck with 285's.
2007 FJCruiser Black ARB/WARN/IPF/OME
1988 4Runner ARB
Scott9000 is offline
Old 06-02-2006, 09:28 AM   #26
Member Number: 639
Yes. IMO the Heavy OME kit has the increased spring rate to handle the additional 200 lbs of a bull bar, winch, lights, hi-lift and whatever else you might want to mount on the front end. I talked to a few people that have installed OME in the past. This helped me make my decision to order the heavy kit. Also the fine folks at Man-A-Fre recommended the heavy OME kit with the ARB + Winch on the front. I've seen a few FJ's on other boards with OME kits and bumpers installed and they all appear to be level. I won't really know until I get the lift and install it.
EDIT: I originally said the medium kit was the one I have on order. I actually am purchasing the Heavy kit.
Old 06-02-2006, 03:15 PM   #27
fj guru's Avatar
Member Number: 2215
great post!
love the photos too.
Ben Frantzen
208-351-2183
Salesman @ Stone's Toyota
'67 Toyota FJ 40 for sale
'72 Toyota FJ 40 for sale
'07 Toyota FJ Cruiser
fj guru is offline
Old 06-02-2006, 03:19 PM   #28
Pancho's Avatar
Member Number: 167
Hey sbechtold, did a mounting kit come with the Warn M8000 for the ARB bumper or is that a separate package/product number? I'm picking my stuff up tomorrow morning and doing this myself, but I've never installed an ARB or an electronic winch, just an old greasy Ramsey PTO winch on an old rusty Willys. I'm looking forward to this one.
"Oh you just keep on using me, until you use me up..." Bill Withers
Pancho is offline
Old 06-02-2006, 03:21 PM   #29
mikey's Avatar
Member Number: 2806
Dang, that looks good! Great posts and pics. Now i need to get one of these so I can push the squegee kids out of my way with out having to worry about the paint! jk
Hug a logger and you'll never hug another tree.
mikey is offline
Old 06-02-2006, 04:17 PM   #30
Member Number: 639
The ARB has the mounting plate built into it. You do not have to purchase a mounting kit. See this picture below. The winch actually bolts to the inside of the bumper.
