Very nice! definitely on the to do list. I like it
__________________ FJ CRUISER TI METAL,C PACAGE,6M,ROCK RAILS, TRD EXAUST,T-MAX 9000 WHINCH,CUSTOM FRONT TUBE BUMPER, OME HEAVY FRONT W/TC UCA, OME MEDIUM REAR, CUSTOM REAR TUBE BUMPER, MORE TO COME
Everything would seem to be a somewhat easy bend with a torch to heat up the plastic except where it mounts in the very front. Maybe if you mounted it in a vise and then torch it and bent it maybe. or a crack in the driveway.
If I were to do it, I'd mount the front first so they line up, then move towards the back. I don't feel that they need to be exactly flush with the bends. If they are tight and snug, that should ok shouldn't it?
Sandoo Blue FJ
this is the front of the vehicle
__
...\ <---- right here (excuse the dots)
.....\ ifs is here
......\________________
FJamming, i am talking about this part right here. I was thinking it would be hard because you do not have much leverage to make that bend piece bend that sharply to put screws through it.
I had another idea too. Make where the front most piece is a little longer than needed , enough to be able to bend it correctly, then trim off the part that makes it too long.
very innovative for sure good fabrication also, i would think with the properties of that material it should slide nicely with minor gouging.
08 BLACK DIAMOND, OFFROAD PACKAGE,CQ,
MORE MODS TO COME IN THE FUTURE RIGHT NOW TOO BUSY SAILING THE SEVEN SEAS WITH THE NAVY!!!!!!!
__
.....\ ifs is here
I can see using a floor jack and some heat to push the skid into compliance. I've successfully done that with 3/8 steel that was off by maybe 2 inches. I know the area you're talking about. The floor jack should be able to force it into place.
Sandoo Blue FJ
