Old 09-14-2007, 06:37 PM   #41
toyotaoffroadFJ's Avatar
Member Number: 13561
Re: Front body mount CHOP!
do you guys use the steel that you cut out to re-weld ..if not what gauge do you use??
toyotaoffroadFJ is offline
Old 09-16-2007, 03:01 AM   #42
FJoel's Avatar
Member Number: 4197
I just used a couple chunks of 1/8" mild steel I found literally laying around on the floor in the corner of my dad's garage. I don't know what gauge that is off hand but I remember it was very close to 1/8" when I took my calipers to it.
For the record, I never removed my mounts (the rubber part). I soaked some rags, and I mean soaking, and just put them around the mount as a heatsink. I switched them up every time I stopped drawing a bead, to let one of the two dedicated rags cool off in the bucket.
I will admit even with this one of my mounts started to flame a little at one point. Did no damage whatsoever because I put it out easy. Just put my gloved finger on it to put it out. There is always a fire extinguisher within reach when I am welding, but so far I've never needed it! Thank goodness!
Ellis Precision:
Battery clamps are in stock and ready to ship!
FJoel is offline
