Found this while searching "Differential Breather" on aol search:
What's your take on it. I guess it just works like an acordian. Sounds to easy and don't know about durability. Chime in with your thoughts.
__________________ 2007 Titanium Metallic and YES I wheel it! TLCA#16880, Gotham City Land Cruisers, Northeast Crew
RASTA Aluminum Skids Daily Driver:2005 Toyota Tacoma C cab http://www.gclcny.com/ http://fjcruisernortheastrun.org/ http://tlca.org/
Creeper Breather - Differential Breather Kit Prevents dirt, debris and water from getting in to your axle through the stock axle housing breather. Expands and contracts to accommodate increase or decrease in housing pressure. Kit includes one housing fitting, clamp and bellows (as shown). Easy installation takes just a few minutes. No hoses to route. Fits all Toyota Pickup / 4Runner solid axle housings (front or rear).
Note: This product is not compatible with the Trail-Gear rear axle 4 link upper link mount kit.
It traps pressure similar to an overflow tank on a coolant system and is not a true "breather". I would be leary that too much pressure may cause failure. I'd go with the proven "up high" method.
Agreed, most of the work involves replacement of the nipples at the diff and actuator. Routing the hoses is the easy part. Actually, it's all pretty easy.
