Re: Road Armor bumper installed!
#1: I suggest you do push the AC line back a bit to make sure you get no rubbing. I recall not needing to move the line while mounting, but don't quote me on that. So if you mount the box else where it should be fine. I would do the fuel line mod for piece of mind. The fuel line cost was about $2, and took about 30 seconds to put on after cutting it.
#2: Oh, the lights... Yeah, put those bad boys on BEFORE mounting the bumper. It would be a real pain to try to put those on after the fact. I mounted the PIAA switch under the steering wheel out of site for now. I plan on putting it on a Tacoma Fog light switch into one of the FJ's blank switches for a factory look.
The wiring is easy if you follow the PIAA instructions. The lights come with their own relay. Only need to hook up the power, ground, and the power on line.
The Tick!
"No one sends the Tick anywhere. Fate is my only master. Destiny signs my checks!"-Tick
Click the "The Tick!" above for my build up and to follow the Adventures of The Tick!
