Old 04-22-2008, 08:33 PM   #1 (permalink)
action381's Avatar
Member Number: 6681
Question 3" lift and tires still rub???
Can anyone help me out with this. I put a skyjacker 3" lift on my FJ. I have a set of pro comp 17x9 wheels with 33x12.5x17 mickey thompson baja mtz's. When I'm almost in full turn the tires rub on the body mount(fender where the mud flap is). I live in Oregon and have no idea where to go to get a body mount chop. Will the All-Pro 1" leveling spacer correct this problem? Any help would be great... Thanks!!!
action381 is offline
Old 04-22-2008, 08:35 PM   #2 (permalink)
1983FJ60's Avatar
Member Number: 2652
Re: 3" lift and tires still rub???
learn to live with it.
because it won't be fixed unless you chop.
i was once a rich man. spent my fortune on whores and drink.
1983FJ60 is offline
Old 04-22-2008, 08:46 PM   #3 (permalink)
CruiserChris's Avatar
Member Number: 17036
Metal Tech (Metaltech4x4.com) in Newberg. They do a really professional job for ~$250. Plus, they are really great guys. I'm actually scheduled for a little body mount surgery with them this Friday.
"Bullwinkle"
'07 AT Ti Metallic - ARB Bullbar - Warn XD9000 - OME 885/895 Lift - BFG 285/70/R17 M/T KM2's on 17x9 ProComp Xtreme Alloys - IPF Aux Lights- IPF JO1 Hybrids - Stock Roof Rack "Diet" - OEM Sliders - Uniden PC78 CB -Bandi Mount w/ 3' FireStik - SCUBA Mod - BudBuilts - SCUBA Mod - AP LCA "Pro Links" & skids - AP exhaust tip - Body Mount Chop (c/o Metal Tech)
Member NWFJCC
CruiserChris is offline
Old 04-22-2008, 09:30 PM   #4 (permalink)
action381's Avatar
Member Number: 6681
Thanks for the info CruiserChris... Im going to try to get a hold of them this week and set up a time to get that taken care of... it will totally be worth the time of driving from Eugene to fix this. Thanks again!!!
Old 04-23-2008, 12:04 AM   #5 (permalink)
Money Pit's Avatar
Member Number: 18399
The chop is the solution. I experience the same issue with similar tire/wheel size and lift height. I am going to Demello this weekend for body mount chop to correct problem (and upgrade suspension).
From what I have read on this forum the rub issue varies greatly from vehicle to vehicle sometimes even with similar set-ups. Add the variance between tire and wheel combinations and the potential rub results can be a coin toss.
May be ok on-road but not offroad, etc.
FJ-2007:Titanium Silver-4X4-A/T-Rear Diff Lok
Install History: TRD exhaust/K & N air filter/Warn rear bumper/ARB bull bar/Warn 9.5 XP/A-Trac/Sylvania Silver Star Ultra/Aeroflow HLC/Putco LED dome/17X9 MT/Cooper STT 285 70R17/DO Hybrid sliders/ICON Stage 2 Suspension (extended travel C/O)/ICON Lower Links/Total Chaos A-arm Skids/MAF 4+Plus Skids/Scan Gauge II
Miscellaneous: Hi-Lift/Warn & ARB recovery gear/Powertank #10 system/Staun 6-30 deflators/Halon & Dry chem/Tire repair kit
Money Pit is offline
Old 04-23-2008, 01:28 AM   #6 (permalink)
layonnn's Avatar
Member Number: 10006
Having a 3inch lift does not help you stop from rubbing in that spot. The reason you are rubbing is because you are running 9 inch wide rims and 12.5 inch wide tires. There is almost no way you could have this set-up without rubbing on the body mounts. Chopping is the only way to fix this. I had mine done for 138.
Layton
2007 FJ Cruiser 5AT 4x4
Voodoo Blue
"God forgives...rocks don't"
layonnn is online now
Old 04-23-2008, 05:30 AM   #7 (permalink)
creecros's Avatar
Member Number: 17423
I put 33x12.5x17's on my rig, Dick Cepek Mud Country. 3" Lift as well. No Rubbing! yay...I stuck with my factory rims though...
Silver Scratched 6MT 4x4
3" RC, 33" DC Mud Country, Safari Snorkel, Avic-D3, backup camera, little mirrors inside the big ones & a lot of Scratches.
creecros is offline
Old 04-23-2008, 07:21 AM   #8 (permalink)
Brock's Avatar
Member Number: 18654
Send a message via Yahoo to Brock
I have a 3" lift with no rubbing but I am also running the stock 17" alloy wheels with Nitto TG.... some things that impact it is whether your lift is really giving you a full 3" or more like 2.5 inches once it is said and done. Most give 3" in rear and less in front...ToyTec includes a new coil over strut bracket to replace the oem one that is thicker to make sure you get full 3" in front also.
Then you have the wheels that if the offset is different that will affect the clearance. Finally you have tires...some 33inch tires are 32.5 while others may be 33.2......depending on tread aggressiveness and such.
I know mine do not rub one bit....but when you stray away from stock wheels and the OME lift I cant help. Sounds like you will indeed have to do the frame chop on your truck....
she's a "Brick.......House"
08 FJC, Brick, Auto, Nitto Terra Grapplers (295), ATrac, Locker, Budbuilt sliders, ToyTec 3" lift
Lowcountry Reflections
Lowcountry AMSOIL Products
Brock is offline
Old 04-23-2008, 08:09 PM   #9 (permalink)
action381's Avatar
Member Number: 6681
Thanks everyone for posting... I have a skyjacker performance strut lift with the wheels and tires I stated above. I contacted Metal Tech today and set up a time early May to have my mounts chopped. Im hoping this will correct my problem. I'll post the results once I get this done.
Old 04-23-2008, 08:39 PM   #10 (permalink)
[quote=
[/QUOTE]
Yup. I know a guy with a nearly identical setup but running 285/70/R17 stock rims vs. my 285/70/R17 with 17x9's and he doesn't rub but I rub really bad...it all has to do with the wide rims.
"Bullwinkle"
Member NWFJCC
