Installed Donahoe Racing Coil overs - Toyota FJ Cruiser Forum
» Auto Insurance
» Featured Product
Register Home Forum Active Topics Photo Gallery Chat Insurance Garage Blogs Search Today's Posts Mark Forums Read
Old 06-20-2006, 04:31 PM   #1 (permalink)
ropedrag's Avatar
Member Number: 2085
Installed my Donahoe Racing front coilovers. The install was straight forward with the most effort being put into getting the rig jacked up and on the jackstands.
1. Jack the rig up and place on jackstands.
2. Remove the wheels.
3. Remove the keeper and bolt then pop out the outer tie-rod.
4. Remove the strut bar bushing where it attaches to the frame.
5. Remove the top 3 nuts from the existing shock.
6. Remove the bottom existing shock bolt.
7. Minor pry bar action and old shock is removed.
8. Install the new coil over.
9. Put it all back together.
If you know the difference between a 3/8 drive, a box wrench, a torque wrench, coke and pepsi you should be able to handle this in 2 hours. The one mistake I made was when I had to hammer the steering arm to dislodge the taper (#3) by flushing up the castle nut and hitting with a normal hammer. As the castle nut is not solid 100% at the top (gapped for the cotter key) it is a bit weaker than a solid nut and I ended up buggering the threads. I should have used a 2x4 and or a rubber mallet. If you know what I mean you will have 0 problems with this install!
Anyway the install was a complete success and with the factory setting it added 1 ½” of height which is enough to stop the tire rub (285’s BFG AT’s with American racing wheels) Not a lot of difference in the ride quality as I typically notice more difference adjusting tire air pressure than anything else here. The front end is noticeably higher and the headlights need adjusted before they get me into a fight.
When people I dont know come up to me and tell me motorcycling is dangerous I tell them so is talking to strangers!
ropedrag is offline
Old 06-20-2006, 04:33 PM   #2 (permalink)
ropedrag's Avatar
Member Number: 2085
Re: Installed Donahoe Racing Coil overs
More install pictures
ropedrag is offline
Old 06-20-2006, 11:14 PM   #3 (permalink)
TheDuneGuy's Avatar
Member Number: 2249
How does it ride?
07 FJ
305/70/17 MTRs
OME Suspension
www.greatlakesoffroad.org
TheDuneGuy is offline
Old 06-20-2006, 11:20 PM   #4 (permalink)
FJ #8's Avatar
Member Number: 121
what are you using for the rear?
FJ #8 is offline
Old 06-21-2006, 04:25 PM   #5 (permalink)
07FJFAN's Avatar
Member Number: 1496
How does it ride? Did you have to do a realignment of the front wheels??
07 FJ, SUN FUSION - 4x4 AT-Loaded, TOYTEC 3" Lift, BFG AT 285/70/17's, Romik Brush Guard, PIAA 540 DRL, xm.
06 BMW R1200 GS Adventure
07FJFAN is offline
Old 06-21-2006, 04:39 PM   #6 (permalink)
ropedrag's Avatar
Member Number: 2085
The ride is fine. Like I said I actually notice more difference in ride by adjusting tire air pressure than between these coil overs and stock.
I can tell you that when I hit a bump, drop, etc. the front feels like its pouring over the "thing" as opposed to hitting it. That's nice
I am waiting on the Donahoe rear solution before I decide what to do with the rear set up.
And no I did not need to adjust the alignment. Tracking is just fine.
ropedrag is offline
Old 06-22-2006, 10:50 AM   #7 (permalink)
Moderator with no FJ
4RnrJ's Avatar
Member Number: 2492
Once you have your rear on and have everything like you want it, your REALLY should get an alignment done. Remember, it's not all just about drifting or camber. Caster is a major thing as well.
I personally had the alignment done on mine right after my lift and it made all the difference in the world. I had them push my tires as far forward as they would go, so now my clearances are MUCH better.
4RnrJ is offline
Old 06-28-2006, 12:42 AM   #8 (permalink)
Member Number: 2106
What adjustments were changed to "push the tires as far forward" ?
Stuck'n Muck is offline
Old 06-28-2006, 01:01 AM   #9 (permalink)
cruiserlarry's Avatar
Member Number: 2011
Exclamation Re: Installed Donahoe Racing Coil overs
The FJC may track fine, but I'd recommend you have it re aligned. The 2" lift and change in the rake of the vehicle front to rear affect the camber and caster of the alignment, creating tire edge wear and more wander at freeway speeds, even though the vehicle will track straight. If you look closely at the wheels looking head on at the vehicle from ground level, you'll notice the tires taper outward from the top (positive caster) since the donahoes where installed...your tires ride more on the outer edge instead of the bottom of the tread... in general, any height change will affect the alignment on independent suspension, and should be checked and re adjusted...
W6LPB / WPOK492
TLCA #9632
cruiserlarry is offline
Old 06-28-2006, 03:26 AM   #10 (permalink)
Jim_D's Avatar
Member Number: 1605
As an FYI, Reggie, the Toyota tech who did all my installs, tells me that on his FJ, with the RevTek lift, he couldn't get the alignment into specifications; but on mine with the Donahoe's and the Total Chaos UCA's, the alignment was a piece of cake.
Jim
Jim_D is offline
Powered by vBulletin® Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
