Old 04-30-2008, 09:59 AM   #11 (permalink)
Razor J's Avatar
Member Number: 4495
Send a message via MSN to Razor J
Re: Question for those using hellroaring...
I had cancelations at the office and a meter in my FJ--I'll get readings for you in the next hour.
Razor J is offline
Old 04-30-2008, 10:25 AM   #12 (permalink)
Mr R2FJ's Avatar
Member Number: 14854
Send a message via AIM to Mr R2FJ Send a message via Yahoo to Mr R2FJ
awesome, thanks!
.:*~*:._.:*~*:._.:*~*:._.:*~*:._.:*~*:._.:*~*:.
2007 FJC BUILDUP
Mr R2FJ is offline
Old 04-30-2008, 11:01 AM   #13 (permalink)
Razor J's Avatar
Member Number: 4495
Here you go:
Scan guage at idle 13.9 (cold engine)-idle drops with warm engine and scan guage falls to 13.7-13.8 (bounces back and forth). 13.7 warm engine, in drive, at a stop
At the batt posts:
14.1 cold, 14.0 warm engine, 14.0 in drive stopped. I don't keep my best meter in my truck tool box, but I think it is pretty accurate.
R2, I think you are on to something. Your alt output seems low.
Gary
Razor J is offline
Old 04-30-2008, 11:46 AM   #14 (permalink)
Mr R2FJ's Avatar
That's exactly what I would expect, but it's interesting to note that others have also posted 13.2 at idle (which is what I see). Very very strange. Maybe I'll give the dealer a call.
2007 FJC BUILDUP
Mr R2FJ is offline
Old 04-30-2008, 01:15 PM   #15 (permalink)
Mr R2FJ's Avatar
Called the dealer.. The alternator spec @2000 RPM is 13.2-14.8. That's one HELL of a range! CRAZY! I would think the regulator would keep the voltage high unless it became overloaded, but perhaps I'm mistaken?
2007 FJC BUILDUP
Mr R2FJ is offline
Old 04-30-2008, 02:39 PM   #16 (permalink)
Razor J's Avatar
Member Number: 4495
That is a huge range and apparently the "normal" they use is @ 2K RPM, so it could be significantly lower at idle.
I think the regulator will keep the voltage fairly constant with different loads, but the current (amps) will change. I am sure the voltage varies some though. I am no alternator guru and could be wrong.
Ask Hellroaring about this. They might could provide a module with a lower voltage cut out as a swap-or have another suggestion.
Razor J is offline
Old 04-30-2008, 04:01 PM   #17 (permalink)
Mr R2FJ's Avatar
To my understanding (given very limited) is that the alternator regulates it via voltage. It's a voltage regulator. However, I'm still a bit confused there.
From what I can tell the voltage is higher when the batteries (or system is demanding) charge and lower when there isn't much draw. Although I always thought it was the other way around? I'm so very confused.. heh Thanks for posting yoru information though! Someone over on azfj had exactly the same thing I do 13.2v at idle. I still see 13.3 at 2K rpm.
2007 FJC BUILDUP
Mr R2FJ is offline
Old 04-30-2008, 08:17 PM   #18 (permalink)
Razor J's Avatar
Member Number: 4495
R2
Try loading your system with bright headlights and AC/fan on and see if you scan guage shows increased voltage-also see if the HR LED stays on when the system is loaded. My scanguage shows little variation with these manuevers. I do not know if the LED could go out if your secondary batt is taking no charge--my LED stays on constantly in the center position. I have gotten the LED to flash when I had a big load on my backup battery (I have a secondary fuse block on my back up battery and can run my Engle fridge and roof top lights off of that block)
You may have to drive with your headlights on and stereo loud to run the Hellroaring (ha!)
This is all interesting and I don't have the knowledge base to explain it. If you figure it out, let me know..
Razor J is offline
Old 04-30-2008, 08:29 PM   #19 (permalink)
Mr R2FJ's Avatar
Well right now I think it's the voltage regulator. I saw pretty much 13.8v after the car had been turned off for over 24 hrs. The best I can tell right now is that the alternator/voltage regulator just doesn't put out much if there isn't any load on the system. I need to post in the elec section to see if I can find an alternator expert over there.
2007 FJC BUILDUP
Mr R2FJ is offline
Old 05-01-2008, 02:03 AM   #20 (permalink)
spincycle's Avatar
Member Number: 9041
Have ya called Mike Hines up at Hellraring and asked him over the phone? He's helped talk me through a few situations that would have been a headache otheriwise.
call em at 406-883-3801
Mr R2FJ previously said: View Post
Do you ever find yours turning off sometimes because the voltage drops too low? My scangauge shows (yet to be verified with a multi meter) 13.3v a lot and from what I've read the hellroaring shuts off at 13.2. Does anyone else with a scangauge notice voltage this low when the car is running?
I've only been using it a few days but the other day while on the trail I noticed that the led was not illuminated. Turning it to combine would make it light up, so I knew the led was working correctly. Later in the day it lit up again.
Just looking for other experiences with hellroaring out there.
TLCA#17822 / FCC:KD0ECN
'07-6MT-FJC...and a whole BUNCHA stuff.
My thanks to Budbuilt, Lucrum, URD, Tuffy, Springtail, KC, BFG, Valentine One, Cobra,
Engel, BFG, Cobra, Yaesu
Protest the end of poitical dialog by contacting
your favorite moderator(s)!
spincycle is offline
