Old 05-05-2008, 05:26 PM   #31 (permalink)
FJDave's Avatar
Member Number: 12655
Re: Mods Too Expensive - Air Tank
Criminey....if I could afford half of that I'd be in....
On the other hand, I've read the must-read thread entitled "the First $2000." That tells me a lot more than what I thought I knew. So, instead of buying mods because they are cheap or a GB is going on, I will follow the advice in the thread and at least have a plan.
2007 4X2 FJ, Black Diamond, "Frankenstein" - http://socalfjcruiserforums.com/foru...hp?topic=145.0
FJDave is offline
Old 05-05-2008, 05:38 PM   #32 (permalink)
Member Number: 3240
Sean I think high frequency of use justifies the tank. And our cases are likely different.
Knowing you, you're probably airing down 5 times a week plus the buggy. The saved fill time probably gives you a whole extra day saved.
I can realistically go out only twice a month. The decent places are at least a couple hours away and I bring the family. So let's say it's a total of 30 minutes of extra fill time per month with the compressor. The rest of the time it's a daily driver. It's nice to have it mounted out of sight in the engine compartment.
Demello hassles me about this all the time too so I would only get one so he leaves me alone
I'm still going to hassle you about it. You could run a small 5lb tank or 10lb tank and fill your tires up at least a dozen times in about 1min per tire.
Take it from people who have tried to prove others wrong about air tanks. I got tired of being "that guy" sitting on the side of the road in big bear still working on his first tire when everyone else was done and gone. Those cheap little compressors are meant for little car tires not your big ass 35's. You would be lucky to get one to fill your tires up. I use to have two small compressors from Wal-Mart mounted under my hood in the old truck. A LONG TIME ago. The compressors would get hot and stop working after the first tire on a hot day. This was after waiting 15min to get one tire up to 25psi.
I even went so far as to try and put anther AC compressor under my hood. I got pretty far but in the end just bought a air tank.
Wyatt sprung for one of those fancier compressors for his first Tacoma's we did air tanks and fancy mounting with chucks in the front and rear. Even that thing took for ever!
Guess what he has now? AIR TANK! And Sean is right it's easy to find a welding store to refill it. Mine down the street does it for me.
I use my air tank to fill my tires up usually 2 or 3 other trucks and then I blow my interior out before the drive home.
JDEMELLO is offline
Old 05-05-2008, 05:39 PM   #33 (permalink)
mattmainster's Avatar
Member Number: 11822
Send a message via AIM to mattmainster
I bought my ViAir 2.5 gallon brand new off eBay for $35...I'll dig for the link.
Snorkeled, Icons all the way around, 35" BFG A/T's...and some other stuff.
mattmainster is online now
Old 05-05-2008, 05:41 PM   #34 (permalink)
Member Number: 3240
FJDave previously said: View Post
You guys are missing the point of the thread. This is about people who are on a VERY tight budget and wanna get some mods to make life easier and safer on the trails. The Co2 setups and hard-wired compressors are way too expensive for people like me. That's why I started the thread. It's supposed to be a place where we can post cheap, necessary mods.
Your best bet for cheap is too look ahead before you go somewhere and see if there are gas stations after the trail that you could fill up at. I know a couple out there. That is your cheapest and fastest bet.
JDEMELLO is offline
Old 05-05-2008, 05:41 PM   #35 (permalink)
Fjamming's Avatar
Member Number: 6623
Todd, there are a few options not too far from you. List of CO2 fill locations in SoCal
Jason, you should just convince him that he need central airing like Hummers...
Sandoo Blue FJ
SoCal Events Calendar
Fjamming is offline
Old 05-05-2008, 06:43 PM   #36 (permalink)
Member Number: 3240
That has been my dream for years but from what I found it's a roughly 6k system? something like that. I think the company that does those converts is located in socal.
BTW I'm the one that trys to talk Todd out of stuff not into stuff. It's only afterwards he says I should have listen too you. I know the air tank will be the same but only after he burns up a couple compressors.
JDEMELLO is offline
