Old 05-06-2008, 07:35 PM   #1 (permalink)
Bulldogger's Avatar
Member Number: 17490
Rasta Skids
For those of you who installed them I have a question. The L brackets in the instructions (3.2) did you face these foward resting against the cross member? Thanks
FJ with RC 3" lift, Trail Gear rock sliders, Piaa 540 Fogs, Rasta skids and 20% front window tint.
Bulldogger is offline
Old 05-06-2008, 08:42 PM   #2 (permalink)
Tai Mai Shu's Avatar
Member Number: 12455
Re: Rasta Skids
Bulldogger previously said: View Post
You're talking about the 2 smaller brackets? I forgot the number and I don't know where the diagram is. The 2 smaller brackets face forward.
Tai Mai Shu is offline
Old 05-06-2008, 10:02 PM   #3 (permalink)
FJCcrawler's Avatar
Member Number: 19513
Re: Rasta Skids
x2 they have to be put on facing foward, although I though they only fit in one position.
FJCcrawler is offline
Old 05-06-2008, 10:50 PM   #4 (permalink)
DC Cruiser's Avatar
Member Number: 13963
Re: Rasta Skids
They actually face to the sides do they not. You put them in the hole in the top of the crossmember and use the handle to hang onto while starting the bolt. Once the bolt is started threading you can let go of the handle and tighten the bolt. The handle part of the bracket ends up resting against the inside of the crossmember allowin you to tighten the bolt.
GRAMPS TOY: 07 BD "C" Package, 5Spd Auto, Hood Deflector, Vent Shades, Pass. ArmRst, SS Grille Inserts, Black Tundra Handles, Bushwacker Pocket Flares.
OFF ROAD MODS: ARB Winch Bumper, KC Daylighters, PIAA 510 Fogs, K&N Filter, 12,000 lb. Titan Winch w/syn line, SAW Hybrid Suspension (Metal Tech) Rasta 4x4 Ally skids, Pro-Comp 7028's (powdercoated white) & Goodyear 305 x 17 MT/R's, SpyderTrax Spacers. AFE 3" High Tuck Cat Back, AFE CAI,(FJoel)
FUTURE MODS: Rear Bumper, Aux Gas Tank, TRD SC,
ORIGINAL FJ:71 FJ4030 yrs ago) 350 Chevy V8 Conv., 4Spd GMC Truck Tranny, (IT BURNTUP)
DC Cruiser is offline
Old 05-06-2008, 10:55 PM   #5 (permalink)
DC Cruiser's Avatar
Re: Rasta Skids
Oh yeh and dont let go of them until you have the bolt started otherwise they will fall into the crossmember and than they are a beatch to get back out. I know this first hand. LOL
They are actually easy once you understand the logic. The bracket is just a big handle for the nut to hold it inside the crossmember until you get the bolt started.
Have Fun
Old 05-07-2008, 09:01 AM   #6 (permalink)
Bulldogger's Avatar
Re: Rasta Skids
I actually have them facing foward on the outside of the crossmember. If you remove the skid you will see them. The aren't inside the crossmember, is that where they are suppose to be is inside the crossmember?? Directions would have been useful. Thanks.
Old 05-07-2008, 09:51 AM   #7 (permalink)
Re: Rasta Skids
You're correct. The diagram show it face outward. That is incorrect.
Old 05-07-2008, 10:35 AM   #8 (permalink)
GTKrockeTT's Avatar
Member Number: 15581
Re: Rasta Skids
i have them facing outward inside the crossmember.
GTKrockeTT is offline
Old 05-07-2008, 10:47 AM   #9 (permalink)
Re: Rasta Skids
GTKrockeTT previously said: View Post
How do you fit it inside? I thought the brackets can't fit in there. Maybe I installed mine wrong??
Old 05-07-2008, 11:28 AM   #10 (permalink)
Singha's Avatar
Member Number: 12233
Re: Rasta Skids
They will fit inside the cross member. Just have to installed them in like a "J" pattern into the hole/s.
I did mine that way, then lifted up the skid. Peek into the skid plate hole and adjusted the bracket to line up. Installed the bolt. And then tigten.
I faced my brackets outboard like the diagram.
TLCA#18914
GCLC#2083
NYC
Ti 6sp. CQ GY UP C7 37 2Q.
ADDED 6D(x2),EL,V5,WL(x2).
SE Speced PLUS/TRD CAI,Q/Shift,Raditor Cap,JDM TRD gas cap cover.
MODS
AllPro Sliders,E-Locker+Diff skid,R-LCA,Bandi,Digger R-UCA,OME 883+TP14(w/TRDs),Rear AirLift airbags,Rasta Skid plates,TC A-Arm Skids,Lucrum mount WO/winch.
Hella horns,Husky mats,SGII,Osram SilverStar,OEM Brush Guard w/Hella 500FF,LightBar w/ 4 Hella FF50,
Dave Crums NEW Rear Trailing Arm MOUNT.
Singha is offline
