Suggestion for axle upgrade. - Toyota FJ Cruiser Forum
 39Likes
post #1 of 46 (permalink) Old 02-14-2017, 09:16 PM Thread Starter
equalme's Avatar
Quoted: 104 Post(s)
Currently running 315 duratracs which are close to 34.6". I daily drive the FJ for the most part but plan on averaging 3-4 trips a year. I was initially looking into just a basic nitro regear to 4.56 and add a front arb locker but after reading about all the blown diffs that the 8" are known for...well I don't want to have to deal with that while out on the trail..and I'm not that gentle on the skinny pedal either.
What would be the best setup for the price? I guess price wise...no more than $8k including lockers?
'07 FJC 4x4
'15 RCF
equalme is offline
post #2 of 46 (permalink) Old 02-14-2017, 10:03 PM
sbechtold's Avatar
Quoted: 118 Post(s)
Re: Suggestion for axle upgrade.
Diamond Axles - Welcome
Been running Brian's axles for 10 years and couldn't be happier with them. If you call Brian and talk to him he'll help you choose your gears and which setup to go with... I run a Land Cruiser 9.5" rear with an ARB. Can't count the number of times through the Rubicon, trips to the Hammers, Moab, etc. Good luck with the build.
sbechtold is offline
post #3 of 46 (permalink) Old 02-15-2017, 08:37 AM
Cholerabob's Avatar
Quoted: 145 Post(s)
If you change the axles to harder ones, your weak point becomes the Diff... I prefer to break an axle more than a diff in trail...
StrangerRanger likes this.
OME lift Kit, Metal Tech Rear Long Travel, Camburgs Balljoint UCAs, Full Ricochet Skid Plates, All Pro Sliders, Metal Tech Offset LCAs , Luna Dual Battery, Cooper STT PRo 35s on 16' Mickey Thompson Classic Baja Locks, FJToyman Shock Skids, Total Chaos lower link Skids, Boztec Dif Skid, Exp1 front Diamond Bumper, Exp1 Rear Bumper with Carrier, Viper winch, Ricochet Lighted Air Dam
Cholerabob is offline
post #4 of 46 (permalink) Old 02-15-2017, 08:45 AM
Iconic_'s Avatar
Quoted: 1332 Post(s)
Cholerabob previously said: View Post
I believe he means a full differential upgrade. The entire rear end.
There are a lot of options to choose from under $8k.
Iconic_ is offline
post #5 of 46 (permalink) Old 02-15-2017, 08:52 AM
StrangerRanger's Avatar
Quoted: 292 Post(s)
I drool over the currie RockJock 60 and the Currie F9 axles for the FJ rears. They use all the factory mounts and let you use the stock rotors, hubs, and retain the stock bolt pattern. I've seen a couple floating around here on the forum.
Currie RJ60 - $2,485
Currie F9 - $2,485
Currie Rockjock III Install On 4Th Gen 4runner
istambull, scrufy, debFJVT and 1 others like this.
'07 Voodoo 4x4 AT
The Big Blue Build thread
StrangerRanger is offline
post #6 of 46 (permalink) Old 02-15-2017, 09:06 AM
football751's Avatar
Quoted: 20 Post(s)
I recently installed a Currie RockJock60. Main reason I went with it over the F9 was ground clearance. F9 is easier to repair if you break the diff, since it used a 3rd member like the FJ that pulls out the front. But hopefully with the upgrade I won't ever break it.
Main advantage to Currie is it includes all the factory mounts, retains factory ABS and brakes and can be installed 95% in your driveway. Only thing I did was take the new axles, bearings, and my backing plates to a shop to have them pressed on. I would recommend talking to Currie and see if they can mount new backing plates with the bearings to the axles before they ship it to you. If not at least buy new backing plates from Toyota. This would make the job way easier. Getting the stock brakes off the stock axles is easy, getting the backing plates off the axles is a PITA.
Another option is Front Range Off-Road, which offers a 9.5 Diamond Axle complete with all the factory mounting plates for the FJ. I imagine they'd set it up for you with gears and everything. Not sure what axles it uses, but I'd definitely recommend 35 spline axles.
My Build: WHOOP '12
Special thanks to the following vendors:
-Ricochet Offroad
-Metal-Tech
-TRDparts4U
-URD
-Brave Motorsports
-FJNewb
football751 is offline
post #7 of 46 (permalink) Old 02-15-2017, 02:17 PM Thread Starter
equalme's Avatar
Quoted: 104 Post(s)
Correct, the full assembly including diff. I was initially looking into swapping it out with the 8.2" assembly but after pricing it out...~$2000 for used rear assembly plus another $800 or so for re-gear.
'07 FJC 4x4
'15 RCF
equalme is offline
post #8 of 46 (permalink) Old 02-15-2017, 02:32 PM
Quoted: 20 Post(s)
equalme previously said: View Post
You're going to spend twice that on an aftermarket axle. Just something to keep in mind.
My Build: WHOOP '12
-Ricochet Offroad
-Metal-Tech
-TRDparts4U
-URD
-Brave Motorsports
-FJNewb
post #9 of 46 (permalink) Old 02-15-2017, 06:08 PM
Iconic_'s Avatar
I think your on the right track thinking aftermarket. An 8.2 is hard to find at a reasonable price, if I were to do it I would likely just go "all-in" with one of the suggestions above. I was told when I was looking at options since I blew my rear diff, Front Range Offroad would sell me "a 9.5" diff with ARB locker, choice of gear ratio, with pinion flange to bolt to your driveshaft, and pinion spacer installed, about $1950." Add the cost of the housing and your at about $4100
debFJVT, equalme and jamesepoop like this.
Iconic_ is offline
post #10 of 46 (permalink) Old 02-15-2017, 11:48 PM Thread Starter
equalme's Avatar
Quoted: 104 Post(s)
Thanks for the help all!
Any reason not to go with the Diamond axle vs the RJ 60?
I'm assuming on the front end there really isn't much I can do to it other than a re-gear and locker or go all out on a SA which is way out of my budget.
'07 FJC 4x4
'15 RCF
equalme is offline
Human Verification
