Titanium bolts for skids? - Toyota FJ Cruiser Forum
 11Likes
post #1 of 27 (permalink) Old 02-24-2017, 01:45 PM Thread Starter
Papa Dragon's Avatar
Quoted: 99 Post(s)
Took advantage of the warm weather to drop my RCI skids, most of the bolts were so damaged I had to use a Irwin Bolt-grip to get them out.
I have to replace 6 of the bolts and at first I was thinking of getting Fourtreks Rock slider washers but for less money I could replace them with Titanium bolts Pro-Bolt Titanium Hex Head M8 x (1.25mm) x 50mm or even the Titanium Dome head?
Anyone ever do this, did it work?
The chief end of man is to glorify God and enjoy him for ever.
爸爸龙
Papa Dragon is offline
post #2 of 27 (permalink) Old 02-24-2017, 01:55 PM
football751's Avatar
Quoted: 20 Post(s)
Re: Titanium bolts for skids?
I went with Class 10.9 yellow zinc plated when I replaced my skid bolts, instead of the normal Class 8.8
I don't know, but how does the strength of titanium compare to class 10.9?
My Build: WHOOP '12
Special thanks to the following vendors:
-Ricochet Offroad
-Metal-Tech
-TRDparts4U
-URD
-Brave Motorsports
-FJNewb
football751 is offline
post #3 of 27 (permalink) Old 02-24-2017, 02:12 PM
Iconic_'s Avatar
Quoted: 1332 Post(s)
Interesting. Never thought about it.
I've replaced all mine with zinc plated grade 10.9 as well.
Let's look at some charts for strength.
Grade 8.8 UTS = 116 kpsi
Grade 10.9 UTS = 150 kpsi
Titanium Fastener = 149 kpsi
kpsi = 1000 lbs/sq in
UTS= Ultimate tensile strength
There you have it, not any stronger than the much cheaper grade 10.9 bolts. But titanium is lighter and likely more corrosion resistant.
Papa Dragon and debFJVT like this.
Iconic_ is offline
post #4 of 27 (permalink) Old 02-24-2017, 02:21 PM Thread Starter
Quoted: 99 Post(s)
Where did you get you 10.9 bolts from Iconic?
爸爸龙
post #5 of 27 (permalink) Old 02-24-2017, 02:32 PM
Zed 71's Avatar
Quoted: 146 Post(s)
Also have to think about galvanic corrosion. Titanium is on the cathodic side, and aluminum and steel are on the anodic side (outer edges of the galvanic corrosion chart). What this means is any steel or aluminum in contact with the titanium bolt has a high potential to corrode.
2012 TT 6MT: ICON Extended Travel Coil Overs, Icon Rear Lift, Total Chaos UCAs, MetalTech Rear LCAs, OPOR LCA Skids, Skyjacker Links, Richochet/All Pro Skid Plates, Cooper STT Pro 285/75/16, Flowmaster 50 Series, TRD Intake Element, Freedom Windows, Bandi CB Mount (for CB and HAM), 55W 5000k HIDs, 24-inch LED Light Bar and LED Amber Cube Fog Lights (Grill), Interior Zombie Lights.
Zed 71 is offline
post #6 of 27 (permalink) Old 02-24-2017, 02:43 PM
Iconic_'s Avatar
Papa Dragon previously said: View Post
Fastenal. I live a few blocks away and since the company I work at has an account there, Fastenal allows me to get the same discount. It's like half off! Working the system.
I have a lot of them and try to replace them before they get too badly corroded. It also helps none of them are exposed to rocks on the underneath side because of my skids.
Iconic_ is offline
post #7 of 27 (permalink) Old 02-24-2017, 02:55 PM Thread Starter
Quoted: 99 Post(s)
I think the zinc plated grade 10.9 are going to be my best plan. So no one's used the Fourtreks Rock slider washers?
爸爸龙
post #8 of 27 (permalink) Old 02-24-2017, 04:32 PM
brobert225's Avatar
Quoted: 34 Post(s)
Titanium would not be a good choice. Grade 8 would be, with antiseize.
W4CHE (APRS)
TLCA #23984
brobert225 is offline
post #9 of 27 (permalink) Old 02-24-2017, 04:41 PM Thread Starter
Quoted: 99 Post(s)
brobert225 previously said: View Post
I was using grade 8 and they were so badly damaged that I had to use an Irwin Bolt-grip to remove them. Definitely not going with Titanium now, the 10.9 looks like my best bet.
爸爸龙
post #10 of 27 (permalink) Old 02-24-2017, 04:51 PM
Iconic_'s Avatar
Don't the RCI have a plate welded around the bolt heads to protect them? Here are my brother's homemade skids. The 3/16" additional plate protects the bolts pretty well.
pierceg likes this.
Iconic_ is offline
Human Verification
