Old 06-03-2008, 08:22 PM   #11
Toledo FJ's Avatar
Member Number: 14676
Re: Got my air tank in!
cool thanks. Excrement (Lance) and TiTank (Don) have been a huge help in doing all these mods. Thanks guys
Guess What! JESUS WAS BLACK!
Toledo FJ is online now
Old 06-03-2008, 11:07 PM   #12
Member Number: 1654
That is close to where mine is going. My TT has an extra rear crossmember for attatching the front edge of the rear skid. Im going to use two of the skid plate bolts and secure a piece of metal to them and the tank will mount on that metal. My compressor is going under the hood to a custom bent/cut piece of metal. Ill take pics when I do it, Im still waiting on the metal shop to finish the pieces. They only charged me $35 for 2 custom pieces of galvinized steel.
Bart & Julie-Life Saving Firefighting Off-Roading Fools
"Me thinks the world is crazy save thee and me, and at times I wonder about thee." Samuel Johnson, 18th century English writer
"There is a knowledge curve in EMS. You start out at knowing nothing, go to knowing something, progress to knowing a lot, maybe come close to thinking you know everything, and then slowly start to slide down as you realize more and more you know less and less of what you thought you knew. And that is probably the place you want to end up. -Street Watch
'08 Trail Team 6spd w/Icon - SOLD
'97 Land Cruiser w/e-lockers
shfd739 is offline
Old 06-03-2008, 11:33 PM   #13
WESBC's Avatar
Member Number: 6452
Send a message via AIM to WESBC
Looks good
Where did you mount QD's?
-Wesley
WESBC is offline
Old 06-04-2008, 06:21 AM   #14
Toledo FJ's Avatar
shfd739 previously said: View Post
sounds cool. You gotta show us some pics of that. I couldn't mount under the hood for the compressor. There just isn't any room under there!
Old 06-08-2008, 06:59 PM   #15
Toledo FJ's Avatar
Finished the install on the OBA and it is working perfectly now. It took a bit of time to get it totally leak free, but now it is sweet. I decided not to mount the gauge in the dash because of the amount of cutting required. I worry that the plastic will break if I need to pull the dash panel. I did mount the switch there, however. I used a toggle with a boot. I really like how it turned out.
I just put the gauge in the jack compartment cover. It looks good, functions well, and saved me the trouble of routing all that tubing:
I used a T fitting to run two hoses along the frame and I mounted quick connects in the hole in the gusset on my sliders:
Because I used a male end, I had to add a shutoff valve in the line:
If you are installing a kit like this, thread tape is your best friend. I used a TON. She is holding pressure like a champ:
Old 06-08-2008, 07:20 PM   #16
WESBC's Avatar
Member Number: 6452
Toledo FJ previously said: View Post
I used TFE paste with Teflon for my set up, it's a thread lubricant and sealer. It was a lot easier to put the fittings together with the paste rather than the teflon tape. The people I talked to agreed that the teflon tape wasn't sufficient for their 150 psi tanks, and that the paste sealed a lot better. The only downside is that it is a bit messy, but if you are careful, you can do a clean job.
Also for the mounting location of the QD's, I've seen people mount them by the receiver hitch and in the front bumper. It seems like it would be hard to connect a QD when your undercarriage is all muddy after offroading. It would require to get on your knees or back to try and connect the hose rather than a easier to access QD in the front and back.
-Wesley
WESBC is offline
Old 06-08-2008, 11:45 PM   #17
Toledo FJ's Avatar
The tape is holding up fine so far, but thanks for the info. I'll use that stuff in the future.
I mounted my QDs the same way Excrement did. As far as I know he has had no problems so far. I like that it is centrally located on both sides so I don't have to pull the air hose all around to air up. All of it can be changed.... it is just air hose and washers. If I find it a pain in the ass, I'll try mounting where you suggest. I also like the current spot because everything is tucked away and protected.
Old 06-08-2008, 11:56 PM   #18
Member Number: 19892
Tape works great if applied properly.
I've had tape work great for years on high pressure tanks in excess of 250 psi.
The heavy yellow gas line tape works really well since its thicker to start with but the white should work just fine.
~Eric
KJ4ETF TLCA-18721
2007 FJ Cruiser, Black Diamond
A few scratches and some other stuff.
Mountainclimber is offline
Old 06-09-2008, 06:42 AM   #19
Toledo FJ's Avatar
I used the white and put like ten wraps on.... at least. If you use way more than you think you'll need, it should hold the pressure fine.
Old 06-09-2008, 07:04 AM   #20
wesayso's Avatar
Member Number: 5111
Teflon tape is fine if used correctly. Make sure the threads are completely clean before applying the tape. Always wrap in the direction of the thread - ie: the opposite direction you turn the part when assembling. Use only two layers - two complete turns. Keep the tape completely flat, with no bunching. I have used teflon tape for years in high pressure air and steam applications with no issues whatsoever.
Grok FJ
"Wars begin where you will
but they do not end where you please"
But do not worship it,
For it shall pass.
Wesayso's mod up
'77 FJ40
'89 4Runner
'90 4Runner
'89 4Runner #2
wesayso is offline
