Upgrade from factory E-Locker to ARB Air Locker - Toyota FJ Cruiser Forum
 5Likes
post #1 of 15 (permalink) Old 03-17-2017, 04:49 AM Thread Starter
JRock's Avatar
Quoted: 1 Post(s)
Can the factory E-Locker be replaced with an ARB Air locker? I understand the third member is different (Big cutout for it to fit inside) for the factory E-locker setup. If a factory non-locker third member was used, would it physically fit inside the original axle housing? Is the axle assembly different at all for locker vs non-locker axles??
I getting ready to re-gear, adding an ARB to the front, and figured it was worth investigating the possibility of ditching the factory locker while I was at it. I have never been a fan of its operation anyway.
I am about 7,500 miles away from my FJ right now, or else I would simply crawl under and look for myself...
Comments complete
JRock is offline
post #2 of 15 (permalink) Old 03-17-2017, 06:11 AM
sbechtold's Avatar
Quoted: 118 Post(s)
Re: Upgrade from factory E-Locker to ARB Air Locker
Yes you can do it. You will have to weld a piece of steel into the axle housing to close up the opening where the e-locker passes through the face of the axle housing. You will also have to drill and tap a new hole for the third member mounting bolts. You will also need a donor third member from a non-elocked axle. There are a bunch of threads out there on other sites that should guys doing this. I've done it and it's not hard. In your case it may be easier to find a donor non-locked rear axle.
sbechtold is offline
post #3 of 15 (permalink) Old 03-17-2017, 06:20 AM
Hopdup's Avatar
Quoted: 31 Post(s)
I don't see why not. The ARB Locker replaces the open Differential Carrier.
Here you can see the locker is separate. If you add an ARB Locker like this one.
You will have to plug up the gaping hole in the third member.
If your E-locker has failed. You can always swap in a cable mechanism. Like this from Chilkatdesigns.com
thane and StrangerRanger like this.
Hopdup is offline
post #4 of 15 (permalink) Old 03-17-2017, 06:31 AM Thread Starter
JRock's Avatar
Quoted: 1 Post(s)
Anyone have experience trying to trade or sell an E-locker equipped axle for a stock one? Seems like the easiest answer is a one-for-one swap, and a cheap way for someone else to get an E-locker if they can made it work.
Comments complete
JRock is offline
post #5 of 15 (permalink) Old 03-17-2017, 06:42 AM
StrangerRanger's Avatar
Quoted: 255 Post(s)
What year?
'07 Voodoo 4x4 AT
The Big Blue Build thread
StrangerRanger is offline
post #6 of 15 (permalink) Old 03-17-2017, 06:45 AM
Cholerabob's Avatar
Quoted: 143 Post(s)
Easiest way is to buy a new third from guys like East coast gears or Just Differentials, then sell your third.
debFJVT likes this.
OME lift Kit, Metal Tech Rear Long Travel, Camburgs Balljoint UCAs, Full Ricochet Skid Plates, All Pro Sliders, Metal Tech Offset LCAs , Luna Dual Battery, Cooper STT PRo 35s on 16' Mickey Thompson Classic Baja Locks, FJToyman Shock Skids, Total Chaos lower link Skids, Boztec Dif Skid, Exp1 front Diamond Bumper, Exp1 Rear Bumper with Carrier, Viper winch, Ricochet Lighted Air Dam
Cholerabob is offline
post #7 of 15 (permalink) Old 03-17-2017, 07:05 AM Thread Starter
JRock's Avatar
Quoted: 1 Post(s)
strangerranger previously said: View Post
what year?
2008
Comments complete
JRock is offline
post #8 of 15 (permalink) Old 03-17-2017, 07:15 AM Thread Starter
JRock's Avatar
Quoted: 1 Post(s)
Cholerabob previously said: View Post
I was looking to do a quick axle swap with someone that wants an complete E-locker axle for cheap-cheap. Swapping out a complete axle is pretty easy. With my new donor axle removed, I would then installing the third with ARB locker from East Coast Gears, and send in the removed core of the non-locker for my core return.
I am open to suggestions on how to make this process easier and cheaper. Or if I am being down right ridiculous replacing the E-locker.
I am trying to plan this all out to have all the right parts in the right place for when I get home from my travels.
Comments complete
JRock is offline
post #9 of 15 (permalink) Old 03-17-2017, 08:19 AM
Hopdup's Avatar
Quoted: 31 Post(s)
If it still works, I'd stick with the E-Locker. If it's broken that makes sense. Because Toyota doesn't sell the E-Locker as a replaceable part.
Hopdup is offline
post #10 of 15 (permalink) Old 03-17-2017, 08:32 AM
Cholerabob's Avatar
Quoted: 143 Post(s)
Hopdup previously said: View Post
Maybe not the dealer but you can buy the Elocker alone on line new from parts dealer.
Human Verification
