Re: POLL: Have you had your LCA nut/bolt loosen up?
I have the All-Pro LCA. Its the red ones, the really heavy ones! I used the stock bolts. Never had an issue since it was installed. I did tho re-tighten the bolts at about 500 miles later. And it was still tight.
__________________ Jeff B 07, 4X4, Blk, M/T, W/E adjustable, A/P H/D rear lower links, 285 70 17 BFG Mud, Thorley Headers, A/P front bumper, DO rear bumper, DO Sliders, Titan 10,000lb winch, Budbuilt skids, Eclipse AVN 5495, Reverse Cam, CDT Audio ES "braxial" 6 1/2 speakers w/upstage, Helix A2 amp, Galaxy DX 959 CB, Bandi mount, 102" whip antenna, ext spkr. from those now useful headliner spkrs. scan gauge II. Clifford matrix alarm.
"If you don't like it, change it, if you can't change it, change the way you think about it."
JAXTOY previously said:
You should loosen by the bolt, the nut has ridges on it to make it "lock" in place. Don't know what this type of "lock nut" is called, but very effective. And no I have never had problems with these coming loose, I have ICON LCA's.
Huh... I wonder if mine are different or something. It just looks like a normal nut and bolt to me. I have found the opposite to be true... it was much easier to break the nut than the bolt.
TrAiLbUs1 previously said:
The nuts are metal with nylon threads the entire thing is not plastic
The ones I have use are all steel including the threads, but they have a tight nylon "O" ring that is pressed into the top of the nut that gets cut-in by the threads on the bolt so it digs in and offers much resistance to backing off.
DEWFPO
Location: Somewhere in the woods of Northern Alberta, Canada
Once
LR axle
AllPro Ultimate LCAs w/ Johnny Joints
Loctite, new bolts/nuts, and torqued down to spec
Have checked them a couple of times since and they do not seem to have come loose.
- Solo
2007 Toyota FJ Cruiser ... and some mods.
You are just jealous because the voices only talk to me!
When Solomon Kane went forth again no man knew his road.
DEWFPO
Isn't that the same thing? I'm confused can you post up a link...they are all steel with a nylon lining but the threads are steel, pretty sure we're talking about apples and apples here
__________________ Romp Master General Tucson Unified Romping District (TURD)
HEG LUMPER #666 full back!!
TucsonTrail Blazer
Chiva/Gap/cave canyon/rice peak/Chimney Rock
Northern AZ
Broken Arrow/Cinder Hills (Suicide $ Hundered $ Hill)
90% Driver 10% vehicle(quote from drunk Navajo driver) Free Chefj!!! Scuba Drivers unite
We may be talking about the same thing. I've never seen any nylon on the threads thought, unless I misunderstood. I don't have any spares handy at the moment but will see if I can get a pic. DEWFPO
