Old 07-13-2006, 01:18 AM   #21
MissFJ's Avatar
Member Number: 1937
Re: TOYTEC Lift Installed Today
Speaking of bigger.....is it time to find bigger mud pits
MissFJ is offline
Old 07-13-2006, 02:22 AM   #22
TRDSteve's Avatar
Member Number: 2279
Shov3l - I'm new to this. Help me understand. Is yours a spacer lift or coil over? I need your parts list has both. Please explain to a newbie. Either here or PM. TIA
TRDSteve is offline
Old 07-13-2006, 02:29 AM   #23
Voodoogirl's Avatar
Member Number: 1808
This is a coilover, but it has a 1/2 inch TOP plate spacer in the front. Check the part # he got, go to the toyteclifts site and it'll show you pics.
Kathie
'07 FJ Voodoo Blue,
Toyo 295/70-17 M/T's
ToyTec custom lift
Expedition One front bumper
Expedition One rear bumper WITH CARRIER
Expedition One sliders
...and, some Moab dirt
'69 3/4t Camper Special Chevy
Orange w/white roof
'05 V-Star 650 Custom, Blue w/blue flames and lots of chrome
TLCA #16191
Voodoogirl is offline
Old 07-13-2006, 02:42 AM   #24
TRDSteve's Avatar
Member Number: 2279
Gee, thanks!
TRDSteve is offline
Old 07-13-2006, 03:27 AM   #25
Noisycow's Avatar
Member Number: 3046
I want to hear more about this rubbing on the sway bar problem, with a pic if possible.
http://thecomingdepression.blogspot.com/
Noisycow is offline
Old 07-13-2006, 06:55 AM   #26
Toyotatech1's Avatar
Member Number: 1637
Send a message via AIM to Toyotatech1
We are looking into that right now. The Left front came with a small shim spacer and that side clears the strut by maybe a 1/16" The Right side does not have a spacer and sway bra sits on base of strut. We tried loosening all the brackets for the sway bar and tried to pry it foward with no luck not very much adjustment. GSGMAC (graham) will have more posted today Im sure.
Toyotatech1 is offline
Old 07-13-2006, 07:03 AM   #27
Blue Cruise's Avatar
Member Number: 2480
sh0V3L previously said:
the tires are 265 70 17 firestone destination mt's im pretty happy with them. i stuck with stock size for gearing reasons next set there should be gears available by then and ill go bigger
I ran 285/75/16 Destination MT's on my lifted tundra...Great in mud and terrible on wet roads (I liked them though, they're a tough tire). FJ looks great. I'm waiting on my lift from toytec (same as yours except with custom rear coils) and it's killing me. I have new DC-I wheels w/ 34x11.5x17 Mickey Thompson Baja belted waiting to put on!!!
07 Blue FJ (Traded)
07 Pirate Mica Double Cab TRD Tundra w/ 5.7
True stainless dual exhaust system w/ flowmasters
Lead foot
Blue Cruise is offline
Old 07-13-2006, 07:39 AM   #28
Valkyrie's Avatar
Member Number: 1873
gsgmac previously said:
Not to be the bearer of bad news....I installed my OME kit (with the help of Toyotatech1) this evening and the 885 springs/N140S shocks rub against the sway bar. I am kinda pissed, now I have to pull it all off and figure something else out. I am not going to grind my sway bar down to squeeze these things in. I would check with OME and the place you purchased your setup to double check this prior to install, but I will know more tomorrow.
Again, I see no way this setup will work without rubbing on the sway-bar and I am not to keen on relocating or modifying it to accommodate the spring/strut setup. I guess All-Pro overcame this with an offset top bracket, OME dropped the ball here.
GSGMAC
Graham- before you go bonkers, give me a call. No need to get pissed, there's no grinding anything.
No disrespect to Reggie, but something is wrong- I have put on dozens of these myself, just did one yesterday in fact.
You took it to TOP, right? Did he reassemble the coilover correctly (spring wrap & orientation) per his TIS?
I'm not sure how this got mucked up, but I can help you.
Valkyrie is offline
Old 07-13-2006, 08:05 AM   #29
Valkyrie's Avatar
Member Number: 1873
You're at TOP, right? If you want, come on TOD by today and you can look at one and we'll help you figure it out... I'll be here until 8PM.
It'd probably be helpful if you and Graham can come over together with his truck.
Valkyrie is offline
Old 07-13-2006, 08:07 AM   #30
sh0V3L's Avatar
Member Number: 2878
Send a message via MSN to sh0V3L
i just double checked and i have no rubbing the clearances are fine no issues at all
07 Silver FJC A/T
3" ToyTec OME lift
Goodyear 285/70 17' M/T R's
Rear Locker + ATrack Hack
Demello Sliders
All Pro Rear Lower Links
FlowMaster
K&N
sh0V3L is offline
