First and foremost the credit goes to Trader over here New snorkel...homebuilt! - FJC Central.com - Forums, Friends, FJ's and Fun!. I have been tossing around this idea for quite awhile now, well today I did it. I really did not think that 2.5 tube was going to cut it, I opted for 3" pvc. I used 4 90 degree elbows and 1 45 degree elbow near the top plus some straight pvc for the upright piece.
I also ordered a Safari ram air head for the top but the elbow will work for now.
Here is a pic of the mock up of where the tube runs through the cowl area. I had to cut a big chunk out of the plastic and had to grind some of the cowl to get it through there, still better than cutting a four inch hole in the fender. I used one screw through the bottom of the cowl to hold the tube.
Here is pic of the tube coming through the cowl grill, had to also grind some of the tabs with a burr bit to get it to fit.
All mocked up!
I used some satin black Krylon Fusion spray bomb to pretty it up. Red Scotch Brite and clean up with alcohol is how I prepped it.
Don't forget to fill the holes in the air box. I used a couple of screws and seam sealer.
Found these brackets at the hardware store. Attached with screws and two way tape for the A-pillar, don't forget to clean pillar with alcohol.
More in next post.
08' Black Diamond offroad package, Blacked out, scuba mod, vsc cancel switch,Magnaflow muffler and SS tip, 5100 Bilstein adjustables up front, Ome 895 springs and Bilstein 5125's in rear, 285/75/16 Firestone Destination Mud tires,All-Pro transfercase skid, homemade Bandi mount,cobra cb, axe mounted on rear door and shovel mounted on fold down seats, Hi-lift mounted on homemade bracket on spare tire carrier, various recovery equipment, homemade snorkel....
After paint was dry I used some clear urethane seam sealer from my bodyshop, to connect it all, I was going to use pvc cement but I may want to take this apart someday.
Once I got it all glued and the two way tape attached, it felt real solid. I took it for a spin and there is no noise or movement what so ever.
I probably will trim it down some once I get the ram air head.
I will get some better pics from a distance tomorrow.
__________________ 07 BD FJC 4x4 6MT
Donahoe coilovers in the fr
Donahoe springs and shocks in the rr
285/75/r16 BFG M/Ts
gun metal TRD wheels
TRD exhaust
All Pro rock sliders
rr locker
A-trac
afe CAI kit
Pioneer Avic D3 navi
Sirius radio
HID headlights
Source 10# CO2 tank
not bad I have been thinking of doing the same. and excellent move on not using pvc cement. the set up you have will have to be removed to change out the windshield properly they have to remove the cowl where your snorkel comes up through. But looks good.
DONE:
Scuba mod, Body mount chop, Debadge, Airaid CIA, 6" Pro Comp Stage I, XD Series Monster 18's, 325/65R18 Nitto Terra Grapplers.
To Did:
recovery gear, hi lift jack, air system, front skid, rock sliders, bumpers, winch, and how long can a sig be?
Why thank you sir, I am always very pleased when I DIY.
Hopefully I can get it pulled apart if the time comes. If not I can cut it off and start over again. It was real cheap!!!
looks pretty good...im thinkin to the roof line might look a little better..
Yep soon as I get my ram air head I will trim it down. I left it long cause I did not know how big the head will be. Thanks, Justin
Looking at the pictures of your engine compartment looks like you could use the snorkel. I kind of wish that aftermarket design also use the same route seems more straight forward. Nice job.
Way to go! Functional and inexpensive. You can certainly afford to tweak it as time goes one. This looks like it'll breath better then the ARB version.
Sandoo Blue FJ
