Old 07-14-2006, 12:39 AM   #11
cruiseaway's Avatar
Member Number: 91
Re: OME Lift Kit Install
OME !
Way to go! So where's the road / trail report ???
cruiseaway is offline
Old 07-14-2006, 12:46 AM   #12
Toyotatech1's Avatar
Member Number: 1637
Send a message via AIM to Toyotatech1
Graham might have gone to sleep im sure he will see this in the morning and post he was telling me that it handled alot better especially around small turns and going in and out of parking spots. We took it to a construction site to get it dirty a little bit. We went through some pretty rough rocks but we did not climb the dirt piles because the dirt looked loose. Graham there is a huuuuuuuge dirt pile over here off el dorado just west of N. County Road. We need to go for another ride.
Toyotatech1 is offline
Old 07-14-2006, 08:30 AM   #13
Jim_D's Avatar
Member Number: 1605
Nice work Reggie; although I wouldn't have expected anything less from you. See you when I get back in town. Graham and I will compare suspensions while we're in Telluride. The ToyTech springs for mine should be here next week and there's a 4x4 shop here in Crested Butte that is going to do the swap out. I'll give you a call and have you walk them through it when I take it in.
Jim
Jim_D is offline
Old 07-14-2006, 08:49 AM   #14
gsgmac's Avatar
Member Number: 1534
We need to hit that up...all for "testing" the new suspension!
Again, thanks for the install Reggie, you did a great job on my rig and Jim_D's FJ also. I was even more impressed how fast you were able to re-clock the front last night, awesome work man!
If anyone in or around Dallas/Fort Worth needs a lift, bumper,winch, or any other modification, please contact Reggie. He does great work, at a much lower price than a shop, and is a Toyota certified tech. He comes with my highest recommendation.
Vice President of TTR
1972 Freeborn Red FJ40 4x4
gsgmac is offline
Old 07-14-2006, 09:02 AM   #15
Member Number: 3091
Jim D, give us a report from TELLURIDE. I'll be there in Sept. Will do a number of passes. Want to hear how your setup worked for the different trails. Thanks
hoodoovoodoo is offline
Old 07-14-2006, 09:04 AM   #16
Member Number: 3091
Toyotatech, what size tires and wheels do you run with th OME setup?
Old 07-14-2006, 10:19 AM   #17
Valkyrie's Avatar
Member Number: 1873
FJ Cruiser #8 previously said:
any plans to post a step by step write up??
Jeff, the kits come with step-by-step instructions, so no need to worry.
Valkyrie is offline
Old 07-14-2006, 10:34 AM   #18
Jim_D's Avatar
Member Number: 1605
Give us a report from TELLURIDE
I would suspect that between Graham and I, with two digital cameras in tow, there will be a plethora of 4 wheeling pictures that will be posted, staring none other than Graham and mine's FJ's (and possibly any other FJ's that happen to show up; not that we would openly discriminate against any other 4 wheel drive vehicles in attendance).
Jim
Jim_D is offline
Old 07-14-2006, 12:17 PM   #19
gsgmac's Avatar
Member Number: 1534
Bringing the video camera also, so plan on seeing some video of the FJ's consuming some terrain!
We will post a full trail report when we return.
gsgmac is offline
Old 07-15-2006, 10:41 AM   #20
Member Number: 1637
Jim- Thanks, yes defenetly give me a call whe n you get back expecting lots of pics from both you and graham to add to my album
hoodoovoodoo-Graham was running 265/70/17 BFG At but 285's will also work
Graham I will be going out to look for the spacer for the rear brake line this weekend, we can get together early next week and finish it off also the roof rack fix and rear diff breather
