FJ Repair Manual Page IN-20 Number 9 previously said:
FOR VEHICLES EQUIPPED WITH VEHICLE STABILITY CONTROL (VSC) SYSTEM
(a) NOTICES WHEN USING DRUM TESTER
(1) Before beginning testing, to disable the VSC, turn the ignition switch OFF and connect SST to terminals TS and CG of the DLC3. SST 09843-18040
NOTICE:
- Confirm that the VSC warning light blinks.
- VSC system will be reset when the engine is restarted.
- For safety, secure the vehicle with restraint chains while using a wheel dynamometer.
The
FJ Repair Manual is here. (resource referenced from this forum) Page IN-20, item number 9.
I know this subject is old and beaten to death, but wouldn't it be better to disable VSC in a way that is documented by Toyota? You never know what else that plug in the engine compartment does. Plus hooking up a switch to wires that are already inside the car would be much easier.
It looks like the DLC3 is on the driver's side just under the fuse box. TS is pin 12 and CG is pin 4. The SST (09843-18040) is a 'special service tool' that looks like a jumper wire with 3 ends. 2 ends are blade terminals and 1 looks likes it plugs into something.
Can any Toyota techies out there confirm the SST is just a jumper wire?
