Old 12-04-2008, 01:14 AM   #21
BoBoNel's Avatar
Member Number: 7316
Re: ARB bull bar problems, HELP
OMG i'm getting confused. but that happens easily with me.
you are getting rub marks on the body or on the plastic black bumper?
let me go find my tape measure and get those measurments for you. hold on.
chris aka Trail-Mom aka Viking Chunt!!
BoBoNel is offline
Old 12-04-2008, 01:25 AM   #22
rachad6's Avatar
Member Number: 23275
Send a message via MSN to rachad6
Chris am sorry about that
the bumper is contacting the metal under the turn signal as you can see in my pictures
i am measuring from the plastic over fender to the edge of the bumper
thank you
rachad6 is online now
Old 12-04-2008, 01:26 AM   #23
BoBoNel's Avatar
Member Number: 7316
ok...........heres the deal......i just tried to take pics of the space with a ruler and they arent turning out during the night so i'll do this method tomorrow and post up some pics.........
as for measurements....that really depends on your interpretation and where exactly you are measuring.
when the bumper is rounding towards its end.....in some spots i have almost a half an inch and in another spot it'll measure a quarter inch or so.........
we could be measuring differant areas.
if you could take a clearer pic of exactly where you want measured.....possibly with a piece of paper behind it with arrows pointing to where you want your measurements it would help greatly. its difficult for me to see from your pics exactly.
soooo.....post up more pics and i'll work in it tomorrow for you.
k???
BoBoNel is offline
Old 12-04-2008, 01:30 AM   #24
blackseabk's Avatar
Member Number: 7025
Because it is body on frame design there are so many variables to have two FJ has the same clearence within few mm me thinks as longs as it looks visually good and you are not hitting any body parts with extreme flex you are good to go. I installed the ARB and try to keep everything as far away as possible, closest point unfortunately is where the top portion of the brace with the front grille assembly which one of the member had a impact and direct the force on to it causing damage.
blackseabk is offline
Old 12-04-2008, 01:32 AM   #25
BoBoNel's Avatar
Member Number: 7316
rachad6 previously said: View Post
thank you
ok....the metal.
are you sure those contact areas arent from your stock bumper? i have alot of rubbbing on my metal, paint worn off......but it was from the stock bumper. you can see those areas in my photos........are you getting rubbing there?
you wrote: i am measuring from the plastic over fender to the edge of the bumper
thank you
if you could take that picture and point to the areas you want measured. when i look at my bumper and take measurments....the plastic bumper is a few inches wide out from the body and i'm not sure if you are measuring closer to the body to the arb or the farthest away corner. am i making sense? i know......sorry...i'm a chick and women can make things more difficult.......its the perfectionists in us.
BoBoNel is offline
Old 12-04-2008, 01:34 AM   #26
BoBoNel's Avatar
Member Number: 7316
blackseabk previously said: View Post
and i think thats his issue. (body part rub) but you are right.......as for exact measurments within mm is going to be differant on each vehicle i'm sure.........
BoBoNel is offline
Old 12-04-2008, 01:41 AM   #27
rachad6's Avatar
well chris
i think i will have to work on it and try different set ups
i already dropped it all the way down i will center it left to rigt like the ARB tech said and see what happens
the rubbing started when i installed my ARB bull bar not when the factory bumper was installed
thank you so much Chris
thank you all
Old 01-14-2009, 08:23 AM   #28
Citytrooper's Avatar
Member Number: 22806
Send a message via AIM to Citytrooper
I was told to install it as far as possible and the previous owner added another bolt to prevent this from happening.
2007 FJC-Canyon City
Citytrooper is offline
