Old 12-03-2008, 11:49 AM   #1
rachad6's Avatar
Member Number: 23275
Send a message via MSN to rachad6
ARB bull bar problems, HELP
Hey guys
I installed my arb bumper with an M8000 winch
All was well, after taking it offroad I noticed that the bumper was touching the body work under the turn signal on both sides
I contacted ARB they said that I need to lower it and that it should be minimum 5 mm between the lowest point of the bodywork under the turn signal and the bumper
They were right I had it at 3mm so I dropped it to 6mm to be on the safe side and tested it on a forklift by flexing the suspension all was well
Now it’s only contacting the body on the passenger side, peeling off the paint(picture 1)
I called ARB they said that it should be adjusted left to right
After measuring it I got 12mm on the driver side between the plastic over fender and the wing of the bull bar(picture 3)
And I got 10mm on the passenger side(picture 2)
Meaning that I need to move it 1mm to the passenger so I would have 11mm on both sides
Will 1mm make that much of a difference
Knowing that I measured everywhere else and it all seemed ok and I sent pictures to ARB and they said it’s ok except for left and right
I need any feedback from anyone who had this problem and can u tell me if its centered on your trucks and if you can provide some exact measurements
Thank you
arb-bull-bar-problems-help-dsc00400.jpg  arb-bull-bar-problems-help-dsc00402.jpg  arb-bull-bar-problems-help-dsc00403.jpg
rachad6 is offline
Old 12-03-2008, 12:05 PM   #2
JoeUser's Avatar
Member Number: 15334
Re: ARB bull bar problems, HELP
I just walked down to the parking garage and measured mine.
I have 14mm on the driver's side and 11mm on the passenger, and the bumper isn't close to touching the paint or the fender lip on either side. Measurement is from the trim piece under the headlight to the bumper. I've also got about 4mm between the metal body strap just under the painted trim piece and the bumper (at the closest angled point of that body strap).
I don't have a winch installed, though, if that makes any difference.
'08 Titanium 4X4; AT; LD; A-Trac; Uniden PC78XLT CB radio & K40 hatch-mounted whip; Yaesu FT-7800R dual-band HAM radio & Comet SSB2 hatch-mounted 1/4 wave antenna Call Sign: KE5WTX; Toyota extra horn mod; no mud flaps; LT285/70/R17 Hankook Dynapro MT tars; 3" Lift (OME 884 front coils & N140S shocks, ToyTec Medium rear coils, OME N71E rear shocks); SCUBA breather mod; Steel sway bar collars; OutRider Suspension rear shock skids and lower link skids; Digger upper and lower rear links; Rasta4x4 skids; Metal Tech step sliders; Mini-Me OEM roof rack; ARB Bull Bar front bumper; Focuztech fog lights; Hella 500 driving lights
JoeUser is offline
Old 12-03-2008, 12:09 PM   #3
rachad6's Avatar
thank you Joe
it's very weird
i don't know what's going on
did you install yours?
or a shop did it for you?
can you send me some pictures like the one i took
thank you Joe
rachad6 is offline
Old 12-03-2008, 12:14 PM   #4
JoeUser's Avatar
I had some collision body work done, and they installed the bumper (in lieu of another plastic one).
Maybe you can install some thick steel washers to offset the bumper from the frame? I don't know if that'll help or not, but it's an option - especially if you're only talking about a few millimeters...
JoeUser is offline
Old 12-03-2008, 12:20 PM   #5
lonelydriver's Avatar
Member Number: 9102
Rachad,
if you are going to wheel hard, pull the bumper as far forward and down from the body as possible. The mount for the arb flexes a little bit, IF you mount the bumper too close to the body it will bend backwards into your fenders if you take a hard hit.
-Kevin <><
07 Ti 4x4
83 FJ60 Tan under construction
Ex cruiser: 1988 FJ62 very sorely missed.
94 Rx-7 with LS1 Sold...
lonelydriver is offline
Old 12-03-2008, 12:27 PM   #6
rachad6's Avatar
Lonely
i you have some picture that you can send me
it would be great for me to compare or if you can send me some measurments
thnk you
rachad6 is offline
Old 12-03-2008, 11:16 PM   #7
rachad6's Avatar
guys anyhing????
anyone?
rachad6 is offline
Old 12-03-2008, 11:58 PM   #8
Member Number: 10006
I have those marks on mine. But it is not from normal driving. My super swamper was really out of balance and i was in a caravan so i had to keep up. The ARB was shaking like crazy and made some light contact. Most people try and mount it as close as possible so it looks better but this is wrong it should be a good distance away.
In installed mine. What are you asking though. About your only option is to make a new pinning hole through the bumper and mounting bracket.
-Benjamin Franklin"
2007 Supercharged Voodoo Blue
-Layton
layonnn is offline
Old 12-04-2008, 12:03 AM   #9
rachad6's Avatar
i already did that
and dropped it as far down as it goes
but need some measurments if you have them so i can compare
thank you
rachad6 is offline
Old 12-04-2008, 12:09 AM   #10
BoBoNel's Avatar
Member Number: 7316
hubby installed mine. let me go out and take some pictures/measurments for you. i have absolutely no rub and i flex mine a moderate amount. i dont have a winch yet though...but that shouldnt matter. my friend has an arb with winch and his never rubs either.
be back in a little bit
chris aka Trail-Mom aka Viking Chunt!!
BoBoNel is offline
