Old 07-31-2006, 02:36 PM   #1 (permalink)
CO-Jeff's Avatar
Member Number: 1863
Send a message via AIM to CO-Jeff
Vehicle Weight after Modifications
I had the chance to weigh my FJ for charity at Jeep week on Saturday in Silverton.
Total weight 5108 full tank of GAS
LF 1431, RF 1219
LR 1213 RR 1245
Modifications: Tires, Bumper, Winch, Gobi Rack, Stereo and rock rails.
I had my normal complete tool selections, shovel, lots of recovery gear and travel gear.
I was not in the FJ
So I figure once I switch to the winch cable will lose a few lbs, but adding the rear control arms and some more armor and rear bumper with tire carrier it will finish out at 5500Lbs
CO-Jeff is online now
Old 07-31-2006, 03:12 PM   #2 (permalink)
mikey's Avatar
Member Number: 2806
Re: Vehicle Weight after Modifications
Intresting, the weight in the rear is almost distributed eavenly but the front is a bit heavier to the drivers side. Could that be a result of the winch or??
Information is knowledge and knowledge is power
mikey is online now
Old 07-31-2006, 03:14 PM   #3 (permalink)
CO-Jeff's Avatar
Member Number: 1863
not knowing, could be fuel tank ? not sure.
Old 07-31-2006, 06:17 PM   #4 (permalink)
TCao's Avatar
Member Number: 940
Fuel tank is located on driver's side but I suspect the steering assembly and brake master cylinder help make the driver's side a little heavier.
TCao is offline
Old 07-31-2006, 06:22 PM   #5 (permalink)
Brian - VABeach's Avatar
Member Number: 1584
Mebbe that 200 lb difference contributes to the FJ lean some folks have. Surprised it's that much more.
B
Brian - VABeach is offline
Old 08-01-2006, 06:28 AM   #6 (permalink)
TCao's Avatar
Member Number: 940
And the battery should add some 50 lbs on the driver's side as well.
TCao is offline
