Starting Point:
Stock FJ with 285 70 R17 tires.
Fender lip to ground front 35 1/4"
Fender lip to ground rear 37 1/4"
One tire (right front) lift with other on the ground 16.5"
The Kit:
Lower shock bolts, sway bar bar bolts were removed to allow the rear axle to fully extend.
Using a spring compressor to remove the rear springs. The rear spacers are installed and the springs are reinstalled.
To reinstall the panard rod, a ratched tie down is used to glently pull the axle to the right side so the holes line up correctly.
