Old 09-08-2006, 05:20 PM   #131
Hotrodguru's Avatar
Member Number: 3108
Send a message via ICQ to Hotrodguru Send a message via AIM to Hotrodguru Send a message via MSN to Hotrodguru Send a message via Yahoo to Hotrodguru
Re: Rear Locker + ATRAC
Yeah I'm still curious about the question posed above ^^
Regardless, I hit my local Radioshack to get some wire tap-ins and did this mod yesterday. Now I need to go back to doing some wheelin to try it out .
Hotrodguru is offline
Old 09-08-2006, 10:29 PM   #132
Son of a Son's Avatar
Member Number: 3191
Send a message via MSN to Son of a Son
just out of curiosity has anyone considered installing a small switch (breaking the blue/yellow and connecting it to black/orange when in one position and completing the blue/yellow circuit when in other position/s)?
Son of a Son is offline
Old 09-08-2006, 11:18 PM   #133
Tankota's Avatar
Member Number: 3884
You could go through all the trouble to do that, but why? You already have switches for both the ATRAC and Locker, and you can turn either on/off as you please with the mod. if you add a switch, all it will do is not allow you to turn on the locker if ATRAC is on in one position, and allow you in the other.
David Hale
2007 Sun Fusion FJ Cruiser - Project T2
Full Icon suspension - 2.5" reservoir shocks front and rear, Icon UCA's, Icon rear links. 34" Goodyear MT/R's, Bandi Mount, Demello bumpers front and rear, Demello Front Skid plates, 4x150W roof mounted KC's and safari lights, ATRAC-Hack.
2007 Yamaha Grizzly 700fi 4x4
2007 Yaris S-Sedan (DD)
http://www.offroadingadventures.com
TTORA-Socal member #38 TTORA Forum
Trail Crew Member
Tankota is offline
Old 09-09-2006, 02:51 AM   #134
cruiserlarry's Avatar
Member Number: 2011
Thumbs up Re: Rear Locker + ATRAC
Tankota, myself, and several others have been beating the FJCs up while using the A-Trac mod for several weeks now with no ill effects - remember, you can still choose to use everything the normal way if you prefer, this mod just gives you an additional choice (or in toyota FJC-speak, another "tool" for your "toolbox"...). go ahead, take a chance !!!!
W6LPB / WPOK492
TLCA #9632
cruiserlarry is offline
Old 09-09-2006, 02:54 AM   #135
chuckwagon's Avatar
Member Number: 2551
Just chiming in to say I did the ATRAC+locker hack tonight. It was an easy mod, and the test was a success.
In my traditional tightwad style, I did the mod without going to radioshack to spend a few dollars...actually I was just too lazy to go down there and buy the cheap splicer!
All I used was an exacto knife, a soldering iron, and electrical tape.
chuckwagon is offline
Old 09-09-2006, 08:19 AM   #136
Jim_D's Avatar
Member Number: 1605
I used a soldering iron
That's probably the best way to do the mod anyway. With a little shrink wrap and a bit of electrical tape it's extremely difficult to tell anything was ever touched.
Jim
Jim_D is offline
Old 09-09-2006, 08:50 AM   #137
gsgmac's Avatar
Member Number: 1534
Having done two of these mods (mine and Jim_D's) soldering is the way to go. The wires are pretty thin and connectors will have a hard time maintaining contact over time. Soldered joints of this type are not suseptable to water or dust contaimination, where wire connectors are. Both Jim and I wanted connections that would not fail, so soldering was the only choice.
Just a couple of tips:
***make sure your ignition is off and key removed, disconnecting the - battery terminal is not a bad idea either****
(don't need to juice any onboard computers)
1) Use a piece of black 20 gauge wire to extend between the two plugs, this will make the install much cleaner and result in less stress on the connection.
2) Remove the plastic cap (use a small screwdriver to disengage the 4 clips) of the VSC module (large plug), this will facilitate much better access to the blue/yellow wire and you don't have to cut the factory tape. The plug can be pulled out by pulling the white tab towards the front of the vehicle.
3) On the second plug (small one) push down the plastic covering as best you can and tie-wrap it to hold it in place. This plug can be removed by pressing the tab on the top and pulling it out (it is a tough one though).
4) Do not cut the Black/Orange wire, just strip about a 1/4" on insullation off and solder your extension wire to it, you'll have to use tape on this connection (electrical tape is only worth a sh!t if it is stretched and wrapped tight).
5) The best connection would be to cut the prevoiusly mentioned wire and solder the extension wire with the two ends of the blk/org wire and shrink wrap it. I would only suggest this if you are an experienced with soldering. There is not a lot of wire slack, so it does require some skill to solder three wire ends in the engine compartment, unless you have a third arm......
Vice President of TTR
1972 Freeborn Red FJ40 4x4
gsgmac is offline
Old 09-10-2006, 06:55 AM   #138
Mtbcoach's Avatar
Member Number: 2433
gsgmac - thanks for more details and "secrets" to this mod. I'm doing mine this morning and appreciate your insight. Can't wait to find a trial to test it out.
'07 GSJ15, well enhanced
'97 FZJ80 OME J
'71 FJ40 stock
Olde North State Cruisers TLCA delegate
Train Hard, Rest Harder
TLCA 17784 - FCC KJ4KGF
Mtbcoach is offline
Old 09-10-2006, 10:22 AM   #139
Strike's Avatar
Member Number: 4102
Strike previously said:
Did it!!
ryoung previously said:
Normally the ABS light is lit (ABS off) when the rear diff lock is engaged. After the patch, with ATRAC engaged and the rear diff locked, several have noticed that the ABS light is not lit.
Has anyone been able to confirm whether ABS is active or not in this situation? If ABS is still active, is this a problem? I can't imagine how it could be, but there are many well-functioning brains here that might know of a disaster scenario.
Hmmm.... I just noticed that in that pic. When I was wheelin' with the mod the ABS was off. Maybe it has something to do with the order of turning on the Locker and ATRAC. I'll check it out when I get my FJ back from the shop.
lllateralus has a MT and he has the same lights displayed as me. I dunno what's up with that.
lllateralus previously said:
www.702FJCrew.net
Strike is offline
Old 09-10-2006, 10:24 AM   #140
Member Number: 5565
strike i hope your "friend" wasn't involved in this mod in any way!!
FJwidow is offline
