Old 09-18-2006, 05:40 AM   #161
Strike's Avatar
Member Number: 4102
Re: Rear Locker + ATRAC
FJwidow previously said:
strike i hope your "friend" wasn't involved in this mod in any way!!
OH NO!! I borrowed some shrink wrap from him to do the mod!! Other than that he didn't help so it should be ok.
www.702FJCrew.net
Strike is offline
Old 09-18-2006, 10:48 AM   #162
Trader098's Avatar
Member Number: 5698
Your FJ has low mileage......
Just click!
Trader098 is offline
Old 09-18-2006, 05:54 PM   #163
Member Number: 6016
I want to thank you all for making clear in a convoluted way what Toyota or their dealers could not. I just bought an 07 Manual without A-TRAC upgrade package and saved $4000.00 (upgrade packages seem to have gone up in price in 07 and diff lock is now standard). I mucked it up in the back country pretty good and these are my conclusions. TRAC in H lets you keep the revs up pretty good at over 15mph in 1st or 2nd. If the computer bogs the revs to much you can go to HL but loose the TRAC which can also overheat the brakes and shut down the system anyway. At low speed in LL with diff lock there is plenty of traction. Given the vagueness of just what A-Trac is $4000.00 could go a long way in aftermarket radio and accessories. I'd sure like to know how to wire the so called $40.00 A-TRAC switch solution?
WYKYD is offline
Old 09-18-2006, 07:23 PM   #164
MissFJ's Avatar
Member Number: 1937
There is a sticky thread on both solutions
2 cheap and easy A-TRAC hacks
that includes this install w/pics:
A-Trac switch install with pics
MissFJ is offline
Old 09-19-2006, 01:18 PM   #165
Hotrodguru's Avatar
Member Number: 3108
Send a message via ICQ to Hotrodguru Send a message via AIM to Hotrodguru Send a message via MSN to Hotrodguru Send a message via Yahoo to Hotrodguru
Well finally had the chance to try out the mod this weekend and I'm going to have to give it a big thumbs up! At the crest of this climb was a nasty drop off to the left. Since the conditions were muddy and slippery the vehicle would naturally slide down to the left towards some trees. On the right side the front right tire would catch some big roots which meant there was not grip to be had.
Well after some careful manuevering back and forth I was able to shimmy outta the bind. With the rear locker locked and A-TRAC off the front tires would spin with no grip. As soon as I enable A-TRAC I was able to progress forward enough that I could change my approach angle and get out of that tight bind. Once I was facing the direction I wanted to go I turned off the A-TRAC. I wanted some tire spin and a bit more speed to get out...worked like a champ.
Hotrodguru is offline
Old 09-19-2006, 03:23 PM   #166
bigbill25's Avatar
Member Number: 1293
Did you try this with just A-TRAC (no rear locker)?
--Bill
(Sold) 2007 FJ Cruiser, 6-Speed, Voodoo Blue, FE, CQ, UR, GY, CF, 3T, EL
Added: 2Q, 6D, WL, DH, V5, Bentup Sliders, Horn, CB, ToyTec Lift, Gobi Stealth Rack
bigbill25 is offline
Old 09-19-2006, 03:35 PM   #167
Hotrodguru's Avatar
Member Number: 3108
--Bill
If not mistaken Bill I did try it without the rear locked. The left rear tire sat in the drop-off which caused the right rear to lift a bit. My buddy Chris was stuck in the exact same spot before I attempted the climb so I'll ask him to chime in. Another thing is that I was on OEM stock tires. I am still impressed with the capablity even in stock form. Tires this month for sure if some dinero I'm awaiting comes in.
Old 09-19-2006, 03:59 PM   #168
chrisngrod's Avatar
Member Number: 2934
Send a message via AIM to chrisngrod Send a message via Yahoo to chrisngrod
I went up first and couldn't see the drop off to the left or the roots to the right. Pretty blind as you come over the crest. I thought I was going to get the rig stuck between trees. I couldn't open my door. The left rock rail was taking some of the weight off the wheels I'm sure (in Jay's case the plastic on the door). Even with the BFG MTs (not aired down though) I was sliding to the left. The only thing that bothered me was how this little cut was fenced in on one side by trees. The ground was packed pretty hard up here and slick as ever. I went with the cut a couple of feet and then back up on the path after clearing the roots.
It was neat to see the different colored paint on some trees.
00 Spyder w/ 2zzge (Car Domain Page) (sold)
07 FJ Cruiser - 6MT w/ mods, trail recaps and build to include the M416 (also get your own off road blog)
Webmaster of Bundy Hill Offroad | Parts for web design program... 223 Designs
Work in progress - 223 Photography
OEM Rock Rails $75+ Shipping
chrisngrod is offline
Old 09-19-2006, 04:06 PM   #169
Hotrodguru's Avatar
Member Number: 3108
Hey loser!!!!
The question was whether or not you used A-TRAC alone or A-TRACK with the rear locked. I think my rear was locked the entire time and I was toggling between ATRAC on and off. Bill wanted to know .
Old 09-19-2006, 04:17 PM   #170
chrisngrod's Avatar
Member Number: 2934
I am reading this crap on my sidekick. Give me a break. I was using both. You would have needed it up the long climb harold was slipping on.
