Old 08-15-2006, 11:33 PM   #21
Tankota's Avatar
Member Number: 3884
Re: Rear Locker + ATRAC
bandi previously said:
This Weekend at Hatteras NC... Running in some very wet sand... OK.. In the Surf... at a good speed, I was loosing a little traction while in High FWD, and to be able to engage at that point without a complete stop would have helped...
I Agree its not very often you may need this, but ever once in a blue moon ya know'...
From what I've read up on and from talking to others, the issue with the locker on in 4H is that it can then also be on in 2H - along with VSC, which may cause some conflicts. 4H and 4L it's not an issue since VSC turns off automaticaly.. but if you were to have both on in 2H the VSC is going to freak when you turn because the rear wheels are turning at the same speed, it's going to assume you are skidding and take action to control it, which on a locked axle at speed may not be pretty. For it to work we'd need to make sure that when locked it turned off VSC.
David Hale
2007 Sun Fusion FJ Cruiser - Project T2
Full Icon suspension - 2.5" reservoir shocks front and rear, Icon UCA's, Icon rear links. 34" Goodyear MT/R's, Bandi Mount, Demello bumpers front and rear, Demello Front Skid plates, 4x150W roof mounted KC's and safari lights, ATRAC-Hack.
2007 Yamaha Grizzly 700fi 4x4
2007 Yaris S-Sedan (DD)
http://www.offroadingadventures.com
TTORA-Socal member #38 TTORA Forum
Trail Crew Member
Tankota is offline
Old 08-16-2006, 12:44 AM   #22
Member Number: 837
my question is.. what do the little stick truck with the 2 green circles mean on your dash?... I have a stick truck with an x on the driveshaft... meaning locked center diff.
Boooo!
K_os is offline
Old 08-16-2006, 12:48 AM   #23
Tankota's Avatar
Member Number: 3884
On mine that just means 4WD is engauged, the auto's are part time 4wd. On yours, you are 4wd all the time, and the light indicates that your center diff is locked. They both have the same end result.
David Hale
Trail Crew Member
Tankota is offline
Old 08-16-2006, 01:00 AM   #24
lllateralus's Avatar
Member Number: 1931
Hopefully there is NO difference with the 6MT version... Ill be doing this shortly!! Someone do it before me to make sure it works!
EDIT... This DID NOT WORK with my manual tranny FJ! Cutting the blue/yellow wire triggers the ABS, VSC OFF and SLIP indicator lights no matter where the Transfer case lever, and in addition, ATRAC would not work with the locker engaged. Thank the FJ gods that everything returned to normal uppon soldering the wire back together... I was so busy thinking of a what the heck Im going to tell Toyota, almoast had a heart attack.
Man do I feel like an idiot... my splice wasnt good... there was no signal to that wire at all, thus the warning lights.
Needless to say, I fixed it, (soldered to the black/orange instead of splice) and it works... oh, it works beautifully!!! (I USED it to TRY to climb an impossibly steep hill, and the locker locks, and the ATRAC works the front end at the same time. Genious.. pure genious.
***SOLD AND MISSED*** 2007 FJC Diamond Black, Fully loaded 6 speed MT
4 KC Daylighters roof mounted, 33" BFG MT's, Daystar lifted, All-Pro front, rear, side armor
www.LocalBuddy.net <----- a work in progress.
lllateralus is offline
Old 08-16-2006, 03:09 AM   #25
bigbill25's Avatar
Member Number: 1293
PRCruiser previously said:
OK, I dont have the rear locker but I like/want to have the A-trac. When I bought my FJ I ordered the a-trac button but I realized and by reading posts that A-trac wont work if you dont get rear locker even that the locker and the a-trac are 2 different system. So Im looking the schematics of the skid control ecu wondering how to make this possible...if tits possible.
I don't think the locker is required. The locker can only disable A-TRAC. So you should be good to go with the switch mod...
--Bill
(Sold) 2007 FJ Cruiser, 6-Speed, Voodoo Blue, FE, CQ, UR, GY, CF, 3T, EL
Added: 2Q, 6D, WL, DH, V5, Bentup Sliders, Horn, CB, ToyTec Lift, Gobi Stealth Rack
bigbill25 is offline
Old 08-16-2006, 07:56 AM   #26
Thai's Avatar
Member Number: 1669
Wow...good work! This will only make the FJC that much more capable!
Good job.
Thai is offline
Old 08-16-2006, 08:22 AM   #27
Tankota's Avatar
Member Number: 3884
Dang you were up late.. LOL.. might want to edit out your red part, you had me worried for a bit! Glad to see our work has be verified and also tested on an MT now. PS.. You need gas soon.
David Hale
Trail Crew Member
Tankota is offline
Old 08-16-2006, 09:14 AM   #28
smalls's Avatar
Member Number: 3834
Send a message via AIM to smalls
In terms that someone new to 4x4ing, can understand, what situations would you use this modification?
- '07 Voodoo Blue, 6speed MT | Upgrade 2 | A-TRAC | RR Locker | Roof Rack
- Mods To Date: 275/70/17 Goodyear Wrangler MTR's | OME Medium Suspension | Sirius S50 | Silverstar Headlights | DRL's disabled | Flowmaster Series 40 | K&N drop-in air filter | Seat belt Alarm disabled | Satin Black OEM Alloys
- Next: Bumper | ARB Rack | Lights | etc.
-Upstate Cruisers-
-Olde North State Cruisers-
smalls is offline
Old 08-16-2006, 10:13 AM   #29
PRCruiser's Avatar
Member Number: 3524
Send a message via MSN to PRCruiser
--Bill
I rephrase: The week after I bought my FJ I ordered from Matt the a-trac button. When I got the button, I installed it but nothing happened; the myth is that if you dont get the the rear locker upgrade (DL) you cannot add a-trac. So, the deal is if by doing something like the atrac+rear locker wire-thing or so, may activate the atrac even when you dont have the rear locker upg. I am so frustated that I bought my FJ with everything but here in PR the FJs doesnt come w/a-trac unless having a manual tranny.
PRCruiser is offline
Old 08-16-2006, 10:52 AM   #30
bigbill25's Avatar
Member Number: 1293
Hmmm. Now why does Toyota not allow them to be on together as stock? There has to be a reason...
--Bill
