Old 08-15-2006, 09:03 PM   #1
Tankota's Avatar
Member Number: 3884
Rear Locker + ATRAC
10 points to anyone who can tell what this means.
I'm working on the write up/picts as we speak. I'll post back when they are done.
David Hale
2007 Sun Fusion FJ Cruiser - Project T2
Full Icon suspension - 2.5" reservoir shocks front and rear, Icon UCA's, Icon rear links. 34" Goodyear MT/R's, Bandi Mount, Demello bumpers front and rear, Demello Front Skid plates, 4x150W roof mounted KC's and safari lights, ATRAC-Hack.
2007 Yamaha Grizzly 700fi 4x4
2007 Yaris S-Sedan (DD)
http://www.offroadingadventures.com
TTORA-Socal member #38 TTORA Forum
Trail Crew Member
Tankota is offline
Old 08-15-2006, 09:08 PM   #2
laviaomaha's Avatar
Member Number: 1354
Send a message via Yahoo to laviaomaha
Re: Rear Locker + ATRAC
atrack and rear locker ,locked at the same time?
rides
voodoo fjc 2007
acura rsx 2002
ford bronco 1972
f 150 s/c 1993
laviaomaha is offline
Old 08-15-2006, 09:13 PM   #3
VTFJC's Avatar
Member Number: 1223
you have less than 1/4 tank
VTFJC is offline
Old 08-15-2006, 09:15 PM   #4
oldawg's Avatar
Member Number: 1036
A-track and rear locker on at the same time.....Vsc off.... you need gas...you need to get out more (low miles),looks like you got red paint all over , alternator seems to functioning OK,coolant level OK,you can go 200 km hr(nice), looks like you need to dust also
Just smile and wave boys...just smile and wave....
~TLCA #15196~
oldawg is offline
Old 08-15-2006, 09:17 PM   #5
OFRD_GRL's Avatar
Member Number: 2799
Send a message via AIM to OFRD_GRL Send a message via MSN to OFRD_GRL Send a message via Yahoo to OFRD_GRL
your dummy lights work.
~Una
My FJC "George"
OFRD_GRL is offline
Old 08-15-2006, 09:17 PM   #6
Member Number: 837
That's a 08 FJcruiser. They will be able to run rear locker and A-trac from the factory.
maybe the Auto FJCs don't have a center locker light????? mine has a thing with an X in the middle by the one with the x in the rear axle.. I'm confused.
Boooo!
K_os is offline
Old 08-15-2006, 09:23 PM   #7
Kevin'sCorral's Avatar
Member Number: 2721
You people crack me up!
What do you do about ATRAC trying to apply brakes to one of the rear wheels when it's locked? Or maybe it wouldn't ever try because both rear tires will always be spinning at the same rate since they are locked together.
Kevin'sCorral is offline
Old 08-15-2006, 09:29 PM   #8
Member Number: 1749
You are also currently in "Park"
Attilla
Attilla is offline
Old 08-15-2006, 09:32 PM   #9
Member Number: 837
Exactly.. you don't want A-TRAC to apply brakes to rear wheels for several reason. But the most important one is because it'll shatter your rear axle.
The locker already puts a lot of stress to it. Apply brakes and it goes kaboom.
Do you know what A-TRAC even does? why does it apply brakes? so it can fool the open diff to send torque to the wheel that has more traction than the other. If you didn't know how open diffs work. They split the torque based on the wheel taht has the least ammount of torque. A-TRAC Sort of works like a limited slip but it uses brakes/sensors instead of clutches.
So you wouldn't need A-TRAC back there because you always theoretically have 50/50 torque split. But when you lock the rear the front is a good ol' open diff and that's what you don't want. But in my opinion given this option I'd still run A-TRAC by itself most of the times. I only use the rear locker and I have no traction up front and one of the rear wheels is on the air.
Another reason why A-TRAC is better than having the rear locked is because if you haven't noticed the rear locker makes your truck swivel from side to side and not follow the exact line you want. A-TRAC goes where you point your wheels.
edit: by all means I don't plan to be an expert if something that I said is not accurate please feel free to correct me.
Boooo!
K_os is offline
Old 08-15-2006, 09:43 PM   #10
Tankota's Avatar
Member Number: 3884
Ok, here's all the info:
http://www.ttora.com/forum/showthread.php?t=43236
As far as A-Trac with the rear locked, ATRAC only applies itself when on that axle is senses one wheel spining faster than the other. Since the rear is locked, both tires spin at the same speed and ATRAC will not apply itself to the rear axle, only the front when it senses one wheel in the front spining.
David Hale
Trail Crew Member
Tankota is offline
