Old 05-29-2009, 08:21 AM   #101 (permalink)
bandi's Avatar
Member Number: 2261
Re: Swaybar Disconnect, Check it out!!!!
SKINUM previously said: View Post
... and decided to see if the swaybar had any real effect at limiting down travel. So, I put the FJ up on jack stands and had the ext. Icons at full droop. The swaybar reapplied with no issues. I would imagine if the swaybar limited the downtravel at all I would have had an issue reapplying it at full droop. Perhaps the swaybar doesn't limit travel but the links are being overstressed and with time will snap?.....
I'm Not sure how you set this test up but it sounds
like you hung both sides at the same time while you
were on jack stands with the swaybar attached, so
yes, the swaybar shouldn't limit the droop of both
wheels at all, due to the flexable link joints, maybe
at full lock you would see some, but not straight on...
The swaybar should limit droop of one tire if you only
have one at droop, which in most real world
situations would be the case, due to one tire being
stuffed some and the other being at droop (unless
you are catching air at the time ), so the
difference between the two would be less with the
swaybar one then with it off...
I guess I should measure and give the amount when
I have a few miniutes this weekend to play... ...
[[[[[[[[[ DEMELLO FlatTop Bumpers ]]]]]]]]]
The "Bandi Mount" From ALL-PRO OFF-ROAD
bandi is offline
Old 05-29-2009, 03:17 PM   #102 (permalink)
SKINUM's Avatar
Member Number: 18535
Send a message via MSN to SKINUM
The LCA travel is limited by the bolts that attach to the frame. The bolts tighten down onto some rubber bushings. So, there isn't any internal stop. If the lower bolts are loosened the LCA can swing freely. I think most people are adding limit straps in fear of busting a CV. Again for me I beleive the LCA will control the droop before this ever becomes a issue.
bandi previously said: View Post
I guess this could be possible. I haven't concerned myself enough with the issue considering I run withouth the swaybar. Still seems as though it would be a miniscule amount if any.
It's not worth doing if you can't drop some f-bombs along the way!
THE BUILD OF SKINUM CLICK HERE TO VIEW
SKINUM is offline
Old 05-29-2009, 03:29 PM   #103 (permalink)
bandi's Avatar
Member Number: 2261
ahhh... sort of a torsion effect with the rubber !...
bandi is offline
Old 06-01-2009, 06:01 AM   #104 (permalink)
dzolo's Avatar
Member Number: 17045
Send a message via AIM to dzolo
daPitbull previously said: View Post
When you did the install, was your tie rod and/or UCA disconnected either at the ball joint or UCA bolt? I've done a handful of installs on FJs and 4runners and never did I have to do what your describing. I actually have to get a jack under the LCA and jack it up to seat the lower shock bolt.
Honestly I cant remember. It was over a year ago when I did that install. I know there was another guy there that said he had to do the same thing with his Tacoma. I don't think anything was damaged during the install. I have put about 20,000 miles on it since then. I would hope I would have noticed by now.
2007 Black 6MT; No Rack(yet); Toytec 3"; Nitto Terra Grappler 295/70R17 on factory alloys; All Pro Ultimate Rear Lower Links
dzolo is offline
Old 06-16-2009, 04:11 PM   #105 (permalink)
Disruptor's Avatar
Member Number: 10620
Send a message via AIM to Disruptor
Well I love the modification that you made and if its ever a product, I would definitely consider it because these things I know:
I liked the feel with the sway bar off road EXCEPT for tippy like situations where it felt like it slanked over more than usual in those same sits.
I didn't like the feel of having it off when on the road, it was not terrible but passengers that are not used to it really don't like it.
So until there is a device that can keep it from going to far over in a tippy situation that can help stabilize the IFS, then I will hold off due to the exact same reasons John thinks.
Disruptor is offline
Old 06-17-2009, 06:48 AM   #106 (permalink)
bandi's Avatar
Member Number: 2261
^^^ It all depends on the type of Wheeling 'YOU' do,
and what situations 'YOU' get into, like almost every
modification you can do to your vehicle...
For me most times off road, I would rather be disco'd,
either due to location, type of terrain, and how I am
going to drive, or a combination of said items, but on
some occasions offroad, I would rather run with the
swaybar connected, so the option 2007FJ came up
with fits 'MY' use to a tee...
The Disco allows me to choose when 'I' want to have
it disco'd, or when 'I' want it connected, sort of like
why I like the FJ, so 'I' can go where I want when 'I'
want to... ...
bandi is offline
Old 06-17-2009, 08:13 AM   #107 (permalink)
2007fj's Avatar
Member Number: 4059
[quote=Disruptor;1423290]Well I love the modification that you made and if its ever a product, I would definitely consider it because these things I know:
Limiting straps will help reduce the slanking/snap roll effect.
The Beauty of this system is you only disconnect when you want.
Only takes 30 sec or so to remove/install
2007fj is offline
Old 06-17-2009, 08:22 AM   #108 (permalink)
VT_RainMan's Avatar
Member Number: 10271
EDIT: Nevermind... SENT A PM.
2007 FJ 6MT black -n- black
VT_RainMan is offline
Old 06-19-2009, 12:48 AM   #109 (permalink)
TrAiLbUs1's Avatar
Member Number: 12292
THats right folks I'm also SWAY BAR DISCOed
Sorry crappy pics used my fathers camera
Allpro sway bar relocator provided by Tibaal spur of the moment (he just had one lying around LOL) when we realized this was needed for install to keep this beefy massive LINK off the spindle.
Had to get a sway bar relocator from Tibaal, THANK YA BRO! And that was it..the quality is amazing and Mark did one hell of a job on packaging and shipping not a thing missing and he provided instructions (not like its that hard...but he did provide torque specs) Discoed it and drove around town going over curbs and speed bumps and even with that mall crawling crap, I could feel a total difference I've never once driven without the sway so it was pretty amazing..cant wait to hit the rocks this weekend. THANKS again brotha!
With the sway bar attached just driving on the road it seemed to feel better with the heim joint there..could be my excitement getting to me Haven't been this stoked since getting my lift, armor, and all the goodies from Allpro 2years ago
BTW what is everyone using for lube on the heims for future reference?
Romp Master General Tucson Unified Romping District (TURD)
HEG LUMPER #666 full back!!
TucsonTrail Blazer
Chiva/Gap/cave canyon/rice peak/Chimney Rock
Northern AZ
Broken Arrow/Cinder Hills (Suicide $ Hundered $ Hill)
90% Driver 10% vehicle(quote from drunk Navajo driver)
Free Chefj!!!
Scuba Drivers unite
BUSTY AND MY WEBSITE PICTURES FROM THE SUMMIT GET EM HERE
“Money can buy you a fine dog, but only love can make him wag his tail.”
Kinky Friedman
F THE MAN!!!
TrAiLbUs1 is offline
Old 06-19-2009, 06:02 AM   #110 (permalink)
bandi's Avatar
Member Number: 2261
OH U B*T*H !... You didn't tell me you had one
on the way !... Very KOOL BRO !... Congrats !...
Now setup a tripod camera on some obstacles,
and get movies of connected and disco'd... ..
bandi is offline
