Old 08-17-2006, 05:15 PM   #1 (permalink)
Member Number: 1029
2wd low for automatics
Here's a useful modification for slickrock trails.
This only works for automatic transmission-equipped FJ cruisers. You are going to add a switch to the circuit that tells the 4WD Control ECU when the transfer case shifter is in 4WD, causing it to disconnect the front axle ADD.
The 4WD Control ECU is mounted next to the engine ECU, behind the glove box. It has a green wire harness plug. Find the red/black wire at pin 6 and cut it. Run the ends to a convienently located on/off switch. This will now be your 4wd-2wd/low switch. The 4WD light on your combination meter should still indicate if you are in 4WD or not.
People with manual tranny FJCs will need some type of twin stick shifter for that transfer case to get AWD low range.
Alex is offline
Old 08-17-2006, 06:36 PM   #2 (permalink)
tobsilent's Avatar
Member Number: 2078
Re: 2wd low for automatics
Yo, thanks! I've been wanting this one.
great mod....did it to my 03 taco dc.
Bret
07 FJC
tobsilent is offline
Old 08-17-2006, 06:38 PM   #3 (permalink)
Pacifico's Avatar
Member Number: 3115
Looks like another good idea, mostly for climbing surfaces with good traction I take it. Alex, you wouldn't happen be working for the DOD up in Los Alamos while pouring over those FJ Electrical schematics now are you?
'07 Titanium 4wd AT CQ UR2 CY
Pacifico is offline
Old 08-17-2006, 07:40 PM   #4 (permalink)
tobsilent's Avatar
Member Number: 2078
now how about a hack to use the rear locker in any xfer/xmission gear?
Bret
07 FJC
