Old 09-01-2006, 12:53 AM   #11 (permalink)
tisilverFJ's Avatar
Member Number: 1394
Re: Sway Bar Removal
Good Times previously said:
4RnrJ is right on the money.
The need to remove the rear swaybar is not that urgent as compared to the front. The problem with the rear is that even with the swaybar off you will not see a significant improvement worthy of having it off permanently.
If anyone is capable of developing a bolt on front swaybar removal system will make mula since it's cross platform for many other vehicles. I've experimented with some ideas but none worked due to the location of the endlinks. I'm all for it if anyone can make em.
Good luck
x2
Damageinc,
Thanks for working on this. I've been wanting more up-travel from the front also. It didn't look like quick disconnects could be made to work.
TLCA#16292
Toytec custom coil lift,SS brake lines. PM me for Discountshttp://www.toyteclifts.com/fjcruiser...ruiserliftkits
All Phase Offroad diff skid,engine skid,Hi-Lift mount,axe/shovel mount,HD LCA frame mounts.
Spidertrax spacers.
All-Pro HD LCA's,Bandi mount.
FabFours front bumper w/PIAA lights
Stock Toyota steel wheels with 35" MTZ's.Gas/water cans mounted to stock rack. Midland hand-held CB. Thule fairing. OEM rock rails. A-Trac/Locker hack.
tisilverFJ is online now
