Old 08-21-2006, 12:23 PM   #1 (permalink)
bartt's Avatar
Member Number: 1660
Winch recommendations?
I happened to notice that Costco carries an 8000lb winch!. It's some brand I never heard of "Champion", and wondered if anyone knows anything about them.?
For 3 bones I wonder if it is worth a try?
I know Warn is probably the brand to get, but if this one would work I can probably manage the cost of the Demello bumper and a winch. Otherwise I'll be stuck for some time without either..
So, please no flames, just honest opinions... <cringe>
bartt is offline
Old 08-21-2006, 12:33 PM   #2 (permalink)
Member Number: 1629
Re: Winch recommendations?
They are a company based in Southern California and the winches come from China. Not sure on how well they work, but I don't think they're that bad. They also have a line of generators, creepers, jack stands, etc. Plus from what I've heard, companies like Mile Marker and Ramsey get their electric winches from China as well.
Baja500 is offline
Old 08-21-2006, 12:35 PM   #3 (permalink)
Member Number: 2552
<cringe>
OK no flame....you will always get what you paid for. I am also looking for the right winch for my FJ as well. I dont know much about these no-name winch but what I did is, I bought a cheap 2500 pounds winch for my ATV for $89 with remote control and compared with the 2500 pounds of Warn that I have on my other ATV. We tested them next to eachother and they both works fine and I dont see any performance difference other than the cost. The Warn was over $300 and doesnt even come with remote so go figure.
Some one will tell you to go for WARN or something else that cost over $1000. It all depends what you want to use it for and how often do you acutally use it. I have not heard of a story of a failed winch before, not even on this forum. I am dying to see some responses from other members, too. So lets wait. How much is your champion winch ? I saw a lot of no-name brand on Ebay and I was wondering about the same....
dau666 is offline
Old 08-21-2006, 12:44 PM   #4 (permalink)
Moderator with no FJ
4RnrJ's Avatar
Member Number: 2492
Well I know this was talked about briefly on Yotatech, and they noted that at least it is a series wound winch vs. a magnet style. So that's already better than a Harbor Freight one.
And a quick google search found this:
http://www.island4x4.com/4x4tech/pro...nch/index.html
Also look at the Warn Tabor line, it is a cheaper line, but if you don't use your winch a lot.. that or the Champion would probably work fine.
I say, give it a try. With costco's unbeatable return policy, there really is not hing to loose.
4RnrJ is offline
Old 08-21-2006, 12:53 PM   #5 (permalink)
bartt's Avatar
Member Number: 1660
Thanks for being kind guys..
I've never had a winch before so this is new territory for me.
You've pointed out some features that I would not have known to look for.
It was only $300, so I was leary, 'cause if it's to good to be true..
After I posted, I found the other posting on island 4x, which made me reconsider. He seems to favor it.
Perhaps someone here has some experience with this particular winch.
bartt is offline
Old 08-21-2006, 02:19 PM   #6 (permalink)
MoabRat's Avatar
Member Number: 1018
Send a message via MSN to MoabRat
Hi, I saw this winch as well. The question marks for me were quality and mounting points. I wanted something that most mounts are designed for and that leaves Warn/Ramsey. I got a Warn 8000 from 4 wheel parts for just under $500 (with a discount coupon and sale) and that had 100 feet of line, and a roller fairlead. I'm happy with my decision as there is no question of the quality with the Warn m line.
Pics of Our Adventures
Spring Fling III
BRC Moab Partner
TLCA# 16012
U4WDA
MoabRat is offline
Old 08-21-2006, 04:20 PM   #7 (permalink)
Member Number: 2778
4RnrJ previously said:
.....I say, give it a try. With costco's unbeatable return policy, there really is not hing to loose.
I disagree. There's a $30K automobile to lose.
I look at it like buying a parachute. Would you bargain shop for a parachute? You may not need it often, but when you need it, it better work reliably. Not a good place for a "Just Good Enough" type decision, IMHO. Same goes for the line and bumper.
ymmv
postalman is offline
Old 08-21-2006, 04:27 PM   #8 (permalink)
CO-Jeff's Avatar
Member Number: 1863
Send a message via AIM to CO-Jeff
Concur saftey of the FJ is well worth a few dollars, gives you a good feeling, like top ropping when rock climbing
- you can go with a 8K Warn, they are very reasonable or the 9K models are a little more advanced or the caddy 9.5 MOSFET.
CO-Jeff is offline
Old 08-21-2006, 06:58 PM   #9 (permalink)
TCao's Avatar
Member Number: 940
Warn M8000 is my recommendation.
TCao is offline
Old 08-21-2006, 07:04 PM   #10 (permalink)
Member Number: 4528
Send a message via Yahoo to meckdeputyiniraq
my recommendation is MISSFJ..........and im sticking to it..........
meckdeputyiniraq is offline
