I tell the same thing to my wife...I may only have a 3" "package" but I can still run full size "rubber"...
good one.
OME medium, TRD CAI, Lucrum Mount winch, T-max 10,000 winch, 305/70/16 BFG M/t, Demello Skid Plate, Camburg UCA, Lightforce 240 (55W HID), All Pro (Sway Bar Links, Sway Bar Collars, Upper Links, Lower Links, Transfer Case Skid Plate, Lower Link Skid, Lower Shock Mount Skid), Man-A-Fre Long Travel HD Rear Panhard Rod, SS Braided Brake Line Kit, ARB Air Compressor.
Not sure how hard your searched, I posted a link above to pics that are of my rig. I run 35 X 10.5 X 16 Super Swamper SSR tires on wheels with stock backspacing, no spacers. Had OME 886/N140 front, 885/N71e rear but swapped out the fronts for some ICON coilovers.
Here a couple pics just because you asked...
Hope they help...
Thank you
Your Rig is Very Schweet . Is anyone running anything wider?
2003 Lexus IS300 White on Tanabe DF210 springs. Looking for a Fj.
Thank you
Wider will require a different backspacing of the wheel, wheel spacers, extend bump stops, etc. Check for DominicG, ajstoy, karpi, I think they are running 35 X 12.50's and I believe others are also, just not sure exactly who, sorry...
Guys that do or have ran 3" with 35's off the top of my head.
DominicG
Savvyav (first guy to do it)
mattmainster
MudLovingFJ
RocKrawler
cruiserlarry
there are more...
- Thomas Paine
There are more than quite a few of us that run 34x10.50 swampers with 3inch lift as well with no rubbing issues.
Me
bandi
bmthiker
couple others as well.
-Benjamin Franklin"
2007 Supercharged Voodoo Blue
I never really measured but I do know about 5 ledges I make now with no scraping with 6" that I got high centered with the 3", same size tires same driver same line, Here in the Northeast we run tight rocky trails lined with trees, you don't always get to move over 5 feet to try a different line.
aka: Krazyfj
2007 SunFusion FJ Mods:
6" Rough Country lift, 1.25" spacers, 35"x12.5x16 Maxxis Trepadors, AllPro sliders, Body mount chop, Scuba mod, Metal Tech front bumper w/ PIAA Lights, Warn M8000, custom rear control arms & skids, All-pro upper a-arms & Tierods, Over the top skids, Powertank air & homemade tube doors.
TLCA member 18300
Eastern 4 Wheelers VP
Northeast Toyota Crawlers
Yankee Toys
FJ Northeasters
So I'm wondering... with a 6" lift with my set up, because I have a spare on top, if I'd have to worry about being top heavy and more of pucker factor. Obviously I'd have to get wheel spacers and a wider tire to make sure my COG comfortable. I personally feel, that I have better clearance with my 35" tires and my 3" lift because of the tire size. I think ultimately what we're looking for when it comes to clearance is moving that pumpkin up, and you can only do that with tires.
Doesn't sound any different than the trails down here in the SE, the trails I've been on in CO, UT, CA or most anywhere else I've been...
