Re: Different Land anchors for offroading with a Winch.
You can make a do it yourself Land anchor fairly easily.
One style that has been used for the last 30 years is a very basic design .
You start with 2 lengths of flat bar that is 3/16" thick 3" wide and about 30" long .
You need to drill a large hole in the end of each length to accept a 1/2"- 3/4" D- Ring / shackle.
You then need to drill 4-5 x 1/2" holes evenly spaced down the centre of the 2 lengths of flat bar.
Then you just need to get 8 -10 x 14" - 20" long 3/8" ground spikes and you have a foldable easily stored ground anchor.
To set it up you need to attach the Shackle and spread the flat bars out in a Fan shape then hammer the ground spikes into the dirt at a angle of around 45 Deg . It can take some time especially removing it but it is a simple cheap piece of insurance.
Cheers
I have the largest Pull-Pal, I think 14,000 lb rating or something close to that. While I've never had to anchor in sloppy mud, but I've used it quite a bit in deep, Northern MI sand dunes. It has never failed. As mentioned, it is a large and heavy piece of equipment. That is pretty much the only drawback, but then again, you can get a smaller version. I wheel alone most of the time, so for me, it is worth it's weight in gold when I've needed it. I'm not so sure how well it would do on some of the rocky soils here in Western Montana.
To answer the original question: Yes, I've seen the buried log/spare method used in sand and just plain dirt. It is a hell of a lot of work compared to using a good land anchor.
I've seen the Cabella's anchor, but it is nowhere near as solid a design as the Pull-pal.
I have used my Pull Pal many times here in the desert southwest and it is a great tool. When you have no trees or other point to winch off of there just aren't options. Oh and for all of you who say dig a hole for your spare, well we have some serious concrete like soil here.
The only area where the Pull Pal is tough to use is sand, but then again there are better methods for sand.
Oh and I have tried the Cabelas stakes and they just aren't strong enough for the FJC.
enjoy,
1leglance
KE7NKP
Disabled Explorers
Helping the handicapped independently access the backcountry www.disabledexplorers.com
Voodoo Blue driver, night nurse, cigar smoker & all around happy camper
^^^ Yup... the best pullpal demonstration I've ever seen was with 1leglance's rig in New Mexico. Stuck BAD and sunk down in really ridiculous clay-like mud... pulled him right out.
