Old 09-30-2009, 09:26 AM   #1 (permalink)
Gottagetone's Avatar
Member Number: 12336
energy suspension sway bar mounts?
Anyone use the energy suspension sway bar mounts? They are greasable ant $20 buck a pair at autozone. If so, what part number did you use?
“Since you have chosen to elect a man with a timber toe to succeed me, you may all go to hell and I will go to Texas.”
Davy Crocket
My Rig:
Gottagetone is offline
Old 10-01-2009, 03:59 PM   #2 (permalink)
DocME's Avatar
Member Number: 17592
Re: energy suspension sway bar mounts?
I bought some 1-1/8", the size of the sway bar, universal sway bar bushings from Energy suspensions at the local parts store.
The Energy Suspension brackets that retain the bushings has the holes perfectly aligned parallel with the long axis of the truck.
However, the FJ's factory mounts have holes that aren't on an axis parallel with the vehicle they are offset. All you would need to do in enlarge one of the mounting holes to make them work. Also make sure you align the bushing with the sway bar axis to prevent bind or excessive noise prior to snugging the bolts.
I never finished installing them. I did like that they had a greasable zirk, but I was somewhat timid about adding another polyurethane bushing to the system to be yet another source of squeaks out of the front end.
Although now I've tracked down and silenced the rest of the noises so maybe it's time to add them back into the mix.
2007 Black Diamond 4x4 Upgrade Package #2
DocME is offline
Old 02-08-2010, 11:03 AM   #3 (permalink)
Member Number: 27568
Just got the new 4 wheel parts monthly magazine, they have an add for the Energy Suspension poly kit for the FJ now for like 160 bucks.
As the great warrior poet Ice Cube once said, "If the day does not require an AK, it is good."
fish_craze is offline
Old 02-08-2010, 11:17 AM   #4 (permalink)
Went to the website, could not find it. Here are the PN's the ad states:
Front Sway Bar Bushing Set: 8.5135R 29mm ($15.99)
Rear Sway Bar Bushing Set: 8.5136R 17mm ($22.99)
Front Control Arm Bushing Set: 8.3128R ($103.99)
Rear Control Arm Bushing Set: 8.3129R($106.99)
Rear Track Rod Bushing Set: 8.7105R ($15.99)
Hope this might help someone.
Last edited by fish_craze : 02-08-2010 at 11:20 AM. Reason: Put in prices to guve you guys a ballpark figure
