What is the necessity of the clutch start override and how would you use it and in what situation?
I am thinking that if I stalled on an incline and was worried about sliding back I would pull up the e-brake and restart the engine. Then I would just modulete the e-brake while I revved and declutched to get moving without backsliding. This is what I would do if I stalled a sportscar on a hill, but once again I am new to offroading.
Or maybe the above situation is not what the switch is designed for? I really have no clue, and I am not ashamed to admit it!
Start the vehicle.
Put it in LL and move forward a bit.
Turn the vehicle off.
Place it in 1st gear.
Push the override button, foot off clutch, start it.
Watch as your vehicle lunges forward and continues to go without placing your foot on the gas.
I also was wondering about this, at first I thought it was a convienience thing like you don't need to push your clutch in to start it out of gear, or mabey for a remote start, but I realized thats dumb, you still have to go to the rig and push the button, so why not just push the clutch in.
So then I read the manual, it says it's made for overriding the clutch so you can start it in gear, to get out of certain difficult situations. Now for the life of me I can not think of any situation to where I would want to crank my starter in gear.
Can anyone tell me why you would need this?
__________________ Ligten up, it's the internet!
air previously said:
Quote from: BigDouggieDoug
Start the vehicle.
I know it's a Toyota, so it should start all the time, but...say you're on railroad tracks and you kill it. Clutch overide will pull you off the tracks! I've used it after an oil change, to reach in (Make sure it's in neutral) and start it without having to get all the way in. Etc...
A true patriots job is to protect his country from its Government. Ed Abbey
86 4Runner (With 319,000 miles.)
96 Ford F250 Diesel (The farm truck.)
2000 4Runner (Wife's, 156,000 miles.)
07 Black Cherry FJ...MT, roof rack License Plate: AHHMOAB
I didn't stall it on this, but I can tell that if you did get it stuck the manual clutch start would have gotten you over it easily. When I gave it some gas the truck was just bouncing up and down. It needed to be feathered up.
Anytime you get stuck offroading and don't want to slip the clutch or risk going backwards just use the manual clutch override. If you're on a rocky hill and you know gunning it after cranking it back up will probably result in you slamming a rock when the springs compress that's also a good time to use it.
I was on a nice uphill climb, left tire ascending a good sized rock...too much gas and a horrific crunch or two would have ensued...hesitated and stalled...clutch start cancel engaged, key turned and she gently climbed the rock and crept forward awaiting a bit of gas to continue the ascent. Tcao and chrisngrod got it right.
