Old 07-14-2007, 11:22 AM   #1 (permalink)
All-Pro
All-Pro's Avatar
Member Number: 2507
All-Pro's New FOX Shox FJ Coil-Overs & Rear Shocks
We are proud to announce we have joined forces with FOX Shox to bring you the best coil-overs and rear shocks available for your FJ. Those that attended the Summit already got a preview!
From our current press release:
The new rugged All-Pro Off Road FJ Cruiser has led the class in the development of aftermarket suspension components since its debut in the spring of 2006. Leading by design is a value that All-Pro Off Road has incorporated in the business from the beginning. With efforts to help you Build the Ultimate FJ, All-Pro Off Road has engineered a suspension system, while FOX Racing Shox designed and engineered an industry leading 2.0 Coil Over Remote Reservoir Shock, providing Toyota FJ Cruiser enthusiasts with the absolute best in the business.
All-Pro Off Road is proud to announce a marketing partnership that introduces FOX Racing Shox into the Toyota FJ Cruiser market. Designed and built to withstand the harsh terrain of off road racing from the wilds of Baja, Mexico to Dakar, Africa FOX Racing Shox has joined forces with All-Pro Off Road to create the “Ultimate Toyota FJ Cruiser Suspension System” for your off road vehicle.
All-Pro’s Jon Bundrant remarked, “FOX Racing Shox has been designing cutting edge suspension solutions for over three decades. This partnership allows our company to deliver to the market the premier suspension system worldwide. FOX Racing Shox has designed a high performance series of shocks for the Toyota FJ Cruiser and they continue their efforts to bring innovative new suspension products to the forefront. This is only the beginning!”
The All-Pro FOX Racing Shox System features 8-way adjustable compression dampening 2.0 Coil Over Remote Reservoir Shocks on the front and 8-way adjustable compression dampening 2.0 Remote Reservoir’s on the rear.
Introductory priced at $1099 pair for the front, $299 each for the rear.
Questions or comments? Email us at info@allprooffroad.com or call 951.658.7077.
2.0 Coil Over Remote Reservoir’s for the front feature:
· 8-way adjustable compression
· Smooth-bore seamless alloy body
· CAD designed pistons with high flow, low cavitational/ tunable velocity sensitive valving
· Teflon line steel spherical bearings
· Billet aluminum body caps and eyelets
· Shafts are hardened 17-4 stainless steel 7/8” hard chromed
· Clear cadmium body plating
2.0 Remote Reservoir’s for the rear feature:
· Shafts are hardened 17-4 stainless steel 5/8” hard chromed
· Unlike emulsion shocks, remote reservoir shocks can be run at any angle
· Nitrogen gas pressurized to 200 psi
· 650 pound cold wound coil springs
· Offset upper mounts to eliminate the need for sway bar modifications, with high quality hardware
· Adjustable ride height from 0” - 3.5” using supplied spanner wrenches
AVAILABLE EXCUSEVELY AT ALL-PRO OFF ROAD—951.658.7077
Visit us on the web at All Pro Off Road
All-Pro is offline   Reply With Quote
