Re: All-Pro's New FOX Shox FJ Coil-Overs & Rear Shocks
Is ALL-PRO still carring the Walker Evans Setup or
is htis to be it's replacement ?....
allpro previously said:
The All-Pro FOX Racing Shox System features 8-way adjustable compression dampening 2.0
Coil Over Remote Reservoir Shocks on the front and 8-way adjustable compression dampening 2.0 Remote Reservoir’s on the
2.0 Coil Over Remote Reservoir’s for the front feature:
· 8-way adjustable compression
· Smooth-bore seamless alloy body
· CAD designed pistons with high flow, low cavitational/ tunable velocity sensitive valving
· Teflon line steel spherical bearings
· Billet aluminum body caps and eyelets
· Shafts are hardened 17-4 stainless steel 7/8” hard chromed
· Clear cadmium body plating
· 650 pound cold wound coil springs
· Offset upper mounts to eliminate the need for sway bar modifications, with high quality hardware
· Adjustable ride height from 0” - 3.5” using supplied spanner wrenches
· Unlike emulsion shocks, remote reservoir shocks can be run at any angle
· Nitrogen gas pressurized to 200 psi
2.0 Remote Reservoir’s for the rear feature:
· Shafts are hardened 17-4 stainless steel 5/8” hard chromed
Now what do I do... Got to upgrade ?...  ...
