Re: All Pro / Walker Evans
uphill previously said:
What would you attach the limiting strap to? The Sway bar and fab something up by the shock mount to limit that popping that causes the problem? I actually went out to my rig and looked and am perplexed a bit on the whole mounting concept. It has to be on a VERY RIGID upper mount or it will rip out and can't conflict with other suspension motion that goes on during trail running.
RedArt (Beard) offers mounting points as well for these. With a washer you could mount to almost any solid point as long as you know the max length before you want it to actually limit.
The Total Chaos LT kit has the limit strap attach from the inside of the secondary shock mount on the bottom to a clip that is welded on about 1" towards the back of the vehicle from the shock tower and about half an inch down from the top of the frame rail. I think. The picture is not perfect.
- SK
2007 Toyota FJ Cruiser ... and some mods.
You are just jealous because the voices only talk to me!
When Solomon Kane went forth again no man knew his road.
