Old 04-23-2006, 04:27 PM   #10
Tranman
Tranman's Avatar
Member Number: 1053
Re: Anyone put 33's yet? What's stock?
tnegiet previously said:
The apparent problem was/is a bulge(frame?) in the back of the front wheel wells. The clearance tolerance is very small when the wheel is turned. Someone on here loaded some pictures after putting new tires on to show the clearance gap.
so is it a problem or not. You said no rubbing right? even at full lock. What about when you turn the wheel all the way right/left. Thought I read somewhere that there is a problem rubbing when you go full left?
Anyways, your rig looks great and thanks a million for posting those pics.
So if no lift is required for 33", then will 35" fit with a 3" lift? (revtek, i'm thinking, but it shouldn't matter), I lift is a lift to a certain extent. Thanks
Tranman is offline   Reply With Quote
