Too Many Toys previously said:
I just did a Revtek lift & 33X12.50X17's on mine. Slight rub while turning tight on the left body mount, behind the left front tire. No biggy.
I'm going to remove the tire at some point and try to 'relieve' the body mount a bit with a BFH.
I'm using **** Cepek DC-1 17X9 wheels. The tread is just a touch outside the fenders. If you mount the 33X12.50X17 tires on the stock rims you may not have the rub or extension beyond the fender lips? (OEM backspacing & narrower)
A couple of quick & poorly-done pics after it was done...
BTW, I guess the forum doesn't like Mr. Cepek's first name? LOL
Awesome!!! Although I'm not into chromed or the glass finish rims I do like the tires. I have yet to find the perfect size that will have the same looks or at least close to what you have but without the rubbing.
