Old 08-21-2007, 07:57 AM   #8
VooDoo FJ
VooDoo FJ's Avatar
Member Number: 8218
Re: Fuel Filter..is it hard to get to and change?
mikesfj previously said: View Post
To answer your question, It requires removal of the fuel tank, removal and disassembly of the fuel pump/filter/sender assembly. It is doubtful that the filter is available as a seperate unit so cost will be steep.
I believe that you are correct, you have to buy the fuel pump assembly.
2007 FJ MT6||OME 885/895||Firestone Destination 285's||K&N Air Filter||OEM Rock Rails||All-Pro Extreme LCA's, Trailing Link Skids, High Clearance Exhaust||TRD Quick Shifter||Demello Hi-Lift Mount
TLCA #18077
N.C. Beach Buggy Assoc. #12893
TTORA #13074
NRA #149022131
VooDoo FJ is offline   Reply With Quote
