Old 04-27-2006, 11:28 PM   #108
Bink Inc.
Member Number: 1835
Re: will 285/70-17 tires fit?
Hey Ralph, you need to learn the difference between an example and a statement of fact. If you are going to try to act like you know what you are talking about, at least get your figures right.. rerun your numbers..
the actual difference would have have been even less.
If you are going to attempt to be the "guru" and clown me, shouldn't you have gotten the ACTUAL circumferences of the tires in question? how about tire pressures? ( those do in fact effect the actual circumferences, as does weight of vehicle ) how about frictionial losses?? road conditions? the list goes on and on..
Prior to calling me a "noob" you should have done your homework.
Oh yeah, just FYI... using your crude calculations you should of said 36" tires.. 37's would be closer to 18%
Grab your calculator and try again..
Bink Inc. is offline   Reply With Quote
