Thread: Busted diff
Old 09-10-2007, 06:35 PM   #17 (permalink)
uphill
Pacific Coast Moderator
uphill's Avatar
Member Number: 10461
Re: Busted diff
Sean K. previously said: View Post
If you do blow it so bad, you can't move it, take out the rear driveshaft and run it back to pavement in front wheel drive
I've done this before (not with the FJ) and it works just fine. Disconnect the drive shaft, throw it in the back or on the roof and drive home. As Sean said, the only problem comes if you're in the back of nowhere. That's why it pays to go with at least one other rig.
uphill is offline   Reply With Quote
