Re: turn the DRL's OFF!
Just did the first method and it works perfect! No side effects.
One hint that helped me- before you try to disconnect it, slide the connector to the right so it slides off the little bracket. Then you can turn it and lift it a little so you can get to it easier and actually see the tab you have to press to get it to disconnect. (you can slide the one half back on when you are done) Made it real easy.
Lovin' my FJ!!
Alpharetta, GA
